Question about Irons
My domena sp400 does not produce steam
I hve not used the steam press for some time. fitted new domena Filters. It heats up OK but will not steam, although the steam motor is going. How can I fix this myself?
2 Suggested Answers
  • 3 Answers
SOURCE: domena excellence sp400 how to change thermostat
You can get a manual from http://safemanuals.com/brand-user-guide-instructions-owner-manual/DOMENA, unfortunately they charge for there manuals. I believe if you where in the UK asking this question you will get an answer faster from a local dealer! Good Luck!
Posted on Nov 29, 2010
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 | Irons
My domena steam press leaves brown stains on my
You may have to use only distilled water in your iron.
Sep 14, 2014 | Irons
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
Steam escaping?
do the following step:
1) distilled water and softened produce leak , change the water
2)put water until the LEVEL
3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
God bless you
Jul 14, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
For my singer electronic steam press esp2 can i use deironise water instead of distilled as i can not get any distilled water in any of the shops in my area.
You can try the deionized water but you may have trouble with it producing enough steam...water that is too pure may not produce steam well depending on the way it is heated.
If it does not produce enough steam just add a bit of salt to the water and it will work well.
heatman101
Aug 13, 2011 | Singer Electronic Steam Press
Domena excellence sp400 how to change thermostat in steam press need to take a pin out to get access to elements and thermostat
Nov 28, 2010 | Singer Irons
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Irons Logo
29 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
