Question about Smeg DO8C Electric Double Oven
Smeg duco8css cooler fan not working
Usually after the oven has been on a while a fan kicks in to cool it (similar to how a fan on a car works, not the internal fan)however yesterday this didn't happen and I couldn't touch the controls as they were that hot, also the vinyl wrap (!) on my units at the side actually blistered it was that hot, I have checked the oven temperature which seems to be perfect and everything else is working but this 'cooling fan' isn't, has anyone else had this problem? how was it rectified? is it a big job? thank you in anticipation, alison james p.s a speedy response would be appreciated as I have 3 hungry boys!!!
    Problem Solver:
  • 18 Answers
IT IS POSSIBLY THE FAN OR ITS RELAY IS BAD BUT I WOULDN'T JUST GO OUT AND BY EITHER UNTIL THEY WERE CHECKED WITH METER
Posted on Apr 23, 2014
4 Suggested Answers
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
barkencoa
  • 3463 Answers
SOURCE: We have Smeg DUCO8CSS double electric oven. Bottom
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Posted on Jan 19, 2010
  • 11800 Answers
SOURCE: I have a customer who
The motor doesn't spins because the control board isn't powering it. First find out the the wiring between the motor and the board is intact. If it is then the defect is in the control board: either the relay is defective or the control signal coming from the processor is missing. You will need to access the board and test it - the relay can be replaced individually, if the defect is somewhere else the entire board will have to go.
Posted on Jun 10, 2011
Smeg suk61mx8: oven does not work except the cooling fan runs
Check circuit breakers there are two in tandem. One may have tripped.
Mar 27, 2015 | Smeg Ovens
Smeg SE250XUK only oven light works, no fan no heat please help
door switch defective,,try to open close again & again
Feb 12, 2015 | Smeg Ovens
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
Jun 01, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Smeg DO8C Electric Double Oven Logo
80 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
