Question about Bosch Ovens
Bosch hbn131 Oven not heating up, fan & grill OK. Is this a failed thermostat and is it cheap to replace or am I better off buying a new oven?
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: no heat when i switch oven on
    There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
    If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
    Remove and replace.
    If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
    Plz rate my solution.
    thanks,
    Posted on Jan 02, 2009
    barkencoa
    • 3463 Answers
    SOURCE: aeg competence b2190-1m oven not heating
    If the fan is working o/k, then you need replace the oven element.
    To access this, remove inner rear cover of oven, there you will see the circular element.
    Unscrew the screws securing it ,and remove element.
    Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
    please rate my solution.
    Thanks
    Posted on Jan 27, 2009
    barkencoa
    • 3463 Answers
    SOURCE: The oven switches on, and fan spins but doesn't heat up!
    If the oven fan is working o/k, then it is probably the oven element that is faulty, and you will need to replace it.
    Please rate my solution.
    Thanks.
    Posted on Jul 19, 2009
    Tip
    Common heating faults with Bosch HBL 5032 single oven
    For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
    To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
    2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
    3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
    4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
    on Jan 19, 2010 | Bosch HBL 5032 Electric Single Oven
    Tip
    Common heating faults with Bosch HBN 430560B / 430520B single oven
    on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
    Fan oven not heating up
    This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
    • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances
    Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
    Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
    Jan 14, 2011 | Smeg Ovens
    Oven is not heating. Fan is working and grill wor...
    This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
    get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
    Hope this helps.
    May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
    Oven not working - rest of appliance fine
    It is most likely that the oven heating element has failed and will need to be replaced.
    This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
    Jan 17, 2010 | Ovens
    Hbn7052gb/05
    If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
    1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
    To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
    2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
    3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
    4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
    Jul 30, 2009 | Bosch HBL 5032 Electric Single Oven
    No heat when i switch oven on
    Remove and replace.
    thanks,
    Jan 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
    Fan oven not heating, bosch hbn 202t
    May 04, 2007 | Bosch HBL 5032 Electric Single Oven
    Ovens Logo
    Top Bosch Ovens Experts
    ashburton
    reliableservice
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
