Question about ASUS MeMO Pad HD 7
What sd card do you need to reboot and save data?
What sd card do I need to back up user data
    Sergeant:
  • 258 Answers
Micro-SD up to 32Gb.
Posted on May 13, 2014
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Jan 02, 2017 | Tablets & eReaders
I have put 32 gb sd card into excelvan tablet for external storage and its not saving?
Unfortunately, most apps will not load onto an SD card. You'll find that some apps will, if a card is installed, place data there. Mostly the SD Cards are installed for use in storing photos and videos taken by the user with the tablet camera. Newer tablets and smartphones are coming with more and more internal RAM to alleviate the "full" issue, but in most cases, you wither have to give up the new app, or remove one to get another.
Aug 31, 2016 | Tablets & eReaders
Not downloading to the sd card
If you are referring to apps you are downloading, that is probably correct. Most apps will not use the SD card to run (or load). It takes more programming for apps to use the SD card than not to, and since many users do not have an SD card installed, most apps won't use it. That is the falsehood that comes with tablets and eReaders. Users are led to believe that even though the tablet may not have a lot of internal memory that they can add an SD card. That works fine for personal files and photos, but not for apps and their data. Users need to know that if they want a lot of apps on their tablet, they need a tablet with a boatload of internal memory.
Dec 06, 2015 | Tablets & eReaders
What does the reset button look like and where is it located on a zeki TB782B tablet
The Seki TB782B runs on Android 4.0 Ice Cream Sandwich OS. The Zeki tablet has a multi touch screen and responds to a wide array of gestures like pinching, tapping and swiping. It also has an 8GB of internal memory and support up to 32GB of micro SD card, a built-in WiFi, G-Sensor and 3 hours battery life for continuous using. When you asked for the hard reset, this means that there is something wrong with your device. The worst problem is you forgot the pattern lock and you have no option but to reset your device. Resetting your device means deleting all the data, apps, photos and videos that saved on your device. Once you proceed there is no way to retrieve all the deleted data. To perform the hard reset: - Check the battery if there is enough charge to finish the resetting process. - Turn off the device and remove the SD card, if there is any. - You have to press and hold the VOLUME down button and tap the RESET button. The reset button is located between the HDMI and USB ports. - Keep pressing the VOLUME down button until the system menu appears, then release the button. - You can use the VOLUME button to navigate the options, select the WIPE DATA/FACTORY RESET, then press the power button to confirm. - Scroll again and select the Delete all user data, then press the power button to confirm the action. - Wait to finish the rebooting process, it will take several minutes to reboot the factory default settings of your device.
Apr 29, 2015 | Tablets & eReaders
Why wont my Polaroid 4 in tablet hold any data?
you need an addtional sd card to store your data. can use up to 32 GB micro SD card.
Jun 06, 2014 | Polaroid 8-Inch Android 4.0 4 GB Internet...
Picture cant be permanently save on my samsung galaxy tab 3
Sounds like you are saving to the SD card and it has a corruption. See if you can save successfully to the device memory. If so then backup all the SD data and replace the card.
Apr 06, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
Forgotten Password
If your notes are on the SD card then take out the SD card and perform a 'Factory Reset' on the tablet. This will loose all saved data on the device so be careful. Replase the SD card and re download all your apps. The data on the SD card will not be effected.
Mar 13, 2014 | Samsung Galaxy Tab 10.1 16GB WiFi Android...
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
How to save video onto sd card
In the settings of the camera app it should have something called 'default save location' or 'Memory in use' set it to "Ext. SD" card. Most tablets have an internal SD so it is important that you select EXT SD card (external SD card).
If you have already found that setting, and 'Ext SD card' is not listed as an option, you need to format that SD in the tablet itself so it builds the folders it needs. Put it into a PC first though to copy off anything you need because formatting it will delete all data.
Jun 04, 2013 | Mach Speed Trio DROID-7C Android 2.3...
ASUS MeMO Pad HD 7 Logo
52 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
