My indesit model no WIB101 fills up with water but won't do anything after that
    Problem Solver:
  • 17 Answers
Switch for water level or hose that level switch should be clean inside...
Posted on Apr 21, 2014
  • andrea_irvin Apr 24, 2014
    Thanks but I have already tried that
  • senad topcagic Apr 24, 2014
    If the motor is not moving, check the motor brushes
4 Suggested Answers
  • 157 Answers
SOURCE: i have a flashing red
It may think the door is still open. Check the door switch is not jammed.
Posted on Aug 16, 2010
SOURCE: the belt slipped off my
Hi, If the belt shows no sign of wear and its not torn or cracked then you have nothing to loose in trying to put it back on, some machines have a tensioning bolt that can be undone slightly so the motor can be moved down to tension the belt if it seems loose and others do not, but if you anre unsure you can always get a new belt anyway.
Another consideration is that the machines bearings may be getting worn, making the pully go out of alignment (hence the belt coming off), check this by gently pushing the front rim of the stainless tub up and down, if you can feel movement it may be worth getting it checked for bearing failure with a view to getting them replaced.
Hope this helps.
Posted on Feb 13, 2011
  • 4336 Answers
SOURCE: washer filled with water but won't do anything
AT the time that you describe, the lid switch must be closed. Check that switch.
Posted on Jun 25, 2011
My Indesit washer model no IWC61651 ECO fills with water but does not do the wash cycle will run for hrs keep filling water but programme never moving
Lynne,
The drain hose for the washing machine is pushed too far down the standpipe causing the water to siphon out of the machine. Look at the diagram below:
-make sure standpipe is at least 18-30inches high
-only push drain hose in 4-6inches
Aug 16, 2016 | Indesit Washing Machines
WIRING FOR INDESIT WIB101
Hi where on the appliance is the wire is it a connection block can you list a photo
Mar 24, 2014 | Indesit Washing Machines
Indesit 1000 wib101 filling but programme not moving any further
once the machine has filled the next requirement is to heat to temperature on some programmes the machine will agitate on others it wont try a different programme to see if you get any motor action if you do it may be something as simple as a heater failed
Mar 04, 2014 | Washing Machines
My Indesit washing maching WG 1234 T, just keeps filling up and will not start its wash cycle.
Usually, when water fills up to a desired level, for example: choosing a small, medium, or large load. The floating switch will trigger a signal to turn on the motor to turn to start the agitation. In this case, the floating switch is bad or the floating mechanism is not working. Therefore the machine didn't do anything. It needs to access to inside the back panel to check it out. Cheers.
Aug 13, 2010 | Indesit Washing Machines
Water in softener compartment Indesit w101 (not above)
Go to Indesit web site download user guide
http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
Most soap drawers have a plastic latch which needs to be pressed to release it.
You will find that there is a ball of soap congealed in the back of the dispenser drawer
May 25, 2009 | Indesit W 123 Front Load Washer
I, Just got a new washing machine about 2 weeks ago it is a indesit WIB101. The Problem Is That When The washing is finished, the next day it still has 3-4 inches of water left in the bottom of the drum
i bassume the water is coming in after cycle finished. source can be two things.
water valve leaking - not probable on a new machine but to check, turn water off and see if water comes in.
if drain is plumbed into a spigot on the sink trap, when you empty the sink, some of the water will go down the drain hose. to cvure, take the drain hose up in a swan neck as high as possible
Sep 14, 2008 | Indesit Washing Machines
Indesit.
Most Indesit washing machines have hidden filters and are not meant to be customer accessible. If you are referring to the incoming water supply, then in some models, it would be immediately after the connector; if on the other hand, you are referring to the lint/fluff collector/filer, then there is no real filter but rather is a part of the drain system. Normally it is at the very bottom of the machine. You need to remove the lower front panel. There would be 3 clips that holds it in place. Once the inside is exposed, there would be a black circular cover at the right hand side. Unscrew it out and clean the inside. It would normally be filled with water and some other "stuff" so pls have cleaning materials handy and/or anything to absorb the spilling water.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Indesit W 123 Front Load Washer
Got a new washer that has button to drain water but its not draing water or doing spin cycle and keeps coming up with error its an indesit wib101 washer it wont finish any cycle at all
check out the DRAIN MOTOR PUMP ,it could be clogged , take it out , inspect it , clean it , and try again , hope this helps AJ
May 13, 2008 | Washing Machines
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
