Question about Ovens
Neff steam oven
I cooked a turkey easter day with my neff steam oven followed the instructions about using steam when it was cooked it was very dry.
  • 1462 Answers
SOURCE: neff oven won't work after a power cut
you need to reset clock - get your book out and it gives instructions
Posted on Oct 08, 2008
jyackle5
  • 8197 Answers
SOURCE: fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
SOURCE: Help! Trying to speedbake my turkey!! Lost instructions!
obviously your turkey has done for a LONG time. But for the future, the speed bake takes 30% less cook time
Posted on Mar 23, 2009
  • 228 Answers
SOURCE: NO INSTRUCTIONS FOR USE OF
check neff website all manuals are available in pdf format for dowload free of charge
hope this helps.
Posted on Jul 20, 2009
  • 57 Answers
SOURCE: neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Posted on Aug 26, 2009
How do I remove the glass cover for the light in my Jeff oven. I have tried following the instructions in the manual but it will not unscrew.
they get jammed with carbon from cooking i work on these all the time and sometimes have to smash with a hammer to remove it itf you tap it with a piece of wood or a rubber mallet you might break the carbon enough to free it make sure you are turning it the right way as people turn it the wrong way when its upside down.
Feb 19, 2017 | Neff Ovens
Why is mu beko cooker building up steam in the over and making food all soggy comet have told me not to cook food with any water in but thats impossible
You do not normally cook with water inside the oven, ovens are for dry cooking only, rings are for boiling water and used for cooking this style
Jul 12, 2011 | Ovens
The bulb in the main oven no longer works. The problem is that we cannot unscrew the lamp cover, in spite of following instructions in the manual. How can we do this? It is a U1421 oven, approx 10 years...
Hello, I find that spraying pam cooking spray around the lamp cover and letting it sit for a while will help on removing that cover. Rember to clean the excess spray before using the oven...Hope this helps.
Jun 06, 2011 | Neff U1421 Double circotherm Electric Oven
I have recently purchased a Neff double oven UI722 and am experienncing difficulty with the heat control. Most things I cook seem to burn either at the sides or bottom or both . Can you help in any way...
It can be difficult to 'acclimatise' to a new oven particularly if it is a fan oven as cooking times are usually shorter.
Temperature distribution is also different so if you are following your normal cooking temp and time you may need to adjust these so as not to overcook.
Try a few set recipes from the hand book using the set times and temperatures to see if that makes any difference.
Good Luck
Dec 19, 2010 | Neff Ovens
Steam is shooting up from stovetop when I'm using the oven, along the back, right side. Is there some kind of seal that can be repaired? Or does the stovetop need to be replaced?
this is normal,the stove must have this feature in order to cook properly and keep your food from tasting like last years turkey
Mar 06, 2010 | Ovens
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    I Lost the instructions for my GE profile Oven probe. Need advic
    I need oven probe instruction and oven conversion time with the convection oven for cooking a forty pound turkey.
    Nov 25, 2009 | GE Profile JT952 Electric Double Oven
    Oven hotter at the back
    You should always preheat oven to operating temperature before cooking anything.
    Do not put too much in oven, leave plenty af space for good air circulation.
    Do not place any reflective foil or the like on the bottom of oven or shelves, as this reflects heat, and you will get uneven cooking.
    Make sure fan is working efficiently if it is fan assisted.
    Dec 09, 2008 | Neff U1421 Double circotherm Electric Oven
    Ovens Logo
    14 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
