Furnace water shutoff not working
Water overflows
  • Justin Scott Apr 21, 2014
    Hi jeff_garmel, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • jeff_garmel Apr 21, 2014
    i have Macdonald/miller low water cut-off and automatic feed valve. the plumber replaced the cut off, but after the furnace is on for awhile, the water level will end up higher than 1/2 up the sight tube. jeff
  • 149 Answers
Sounds like feed valve bad usually set 30 OR 60 PSI SHOULD BE STAMPED ON VALVE EASY FIX
Posted on Apr 30, 2014
Daewoo washer DWD-F1011, WATER OVERFLOWING, HOW TO SOLVE THIS PROBLEM???
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
Sep 05, 2016 | Daewoo Washing Machines
How much water gal/hr is reasonable to expect from the furnace humidifier overflow in "0 degree" farenheit outside to heat a 1500 square foot normal midwestern house to 72 degrees inside having a norm
There is no flow rating because it would depend on too many factors. What you do need to check is the float valve. The water valve is opening and closing like it should be but the reservoir is filling too much.
Jan 23, 2015 | Humidifiers
I have a Utica gas furnace and the overflow pipe is dripping continuously. What could be the problem?
If your Utica is a high efficiency 90+ condensing furnace, I suspect not too much is wrong. A condensing furnace removes so much latent heat from the burned fuel that it condenses the moisture out of the flu-gases. The result is a very low flu temperature, AND water.
The water must be flowing correctly down the proper drain though, or you could suffer damage to the furnace itself. If there is an 'overflow' pipe and it is running over though, the drain downstream must have an obstruction. Clean the drain out and the overflow situation should go away.
Dec 27, 2014 | Heating & Cooling
Can you have too much water running into the humidifier which would cause it to overflow or put too much water in the pump at the bottom of the furnace?
Yes, it's possible. If you think that's the problem try closing the shutoff slightly. If not then make sure the pump isn't clogged making it back up, and also make sure there's a pad.
Hopefully this helps.
Feb 08, 2011 | Aprilaire Humidifiers
Water is leaking out of the bottom of my furnace. could something be plugged?
What type of fuel does your furnace burn?
Gas does condense more water when it fires, that oil--
and that condensing can be running out--- Usually that would be toward the discharge section of the furnace-- as the exhaust gasses might cool and condense upon leaving the furnace.
Or-- do you have a humidifier on the furnace--and maybe the little water sump is overflowing?
Be brave, and open a panel or two, and look around-- above the area the water is leaking out of-- what is in that area?
Jan 19, 2011 | Heating & Cooling
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
Overflow - Cold water shutoff not working?
Sounds like the cold water valve is faulty. You can try to remove it and clean the inside if it's clogged or replace it completely.
Jun 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Aug 19, 2007 | Maytag PAV2300 Top Load Washer
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
