Question about Yamaha RX-V871 - 7.1 Home Theater Receiver
RXV871 system is not turning on from stand by
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Try disconnecting the power for 20 mins. Does this unit have a remote or does it come on automatically?
Posted on Apr 24, 2014
My2002 R1 won't start no green neutral light when I turn the key the yellow check engine light lights up
Hi, Kevin the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
neutral light wont come on when in neutral and wont start with kick stand.
No neutral light bike won start
Yamaha YZF R1P Service Manual
OEM parts for Yamaha
Yamaha YZF R1P Owner Manual
Sep 22, 2017 | 2002 Yamaha YZF-R1
Triumph trident 93 model side stand works as it should but warning stays on with stand up john
Hi, John either the switch is faulty or the circuit is grounded to the light that being said the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Side stand bypass
Sidestand Clutch Safety switch issues
Triumph TROPHE Service Manual Page 2
http://www.triumphestore.com/
http://mybikemanuals.com/triumph/uncategorized-triumph-owners-manuals
May 09, 2017 | 1993 Triumph Trident 900
Hi, H650, working fine, then erratically just stop, seems electrical problem, side stand switch were suspicious, took it off and bridged the wires, the same problem, Thx
Hi, Tamas the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Runs stops starts backfires
Engine turns off all of sudden when riding
Kawasaki Ninja 650 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Apr 01, 2017 | 2008 kawasaki Ninja 650R
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
How do you check the DCL and charging system?
GO TO THIS LINK FOR A CODE TEST, DCL STANDS FOR "DATA LINK CONNECTOR" THE SYSTEM IS CALLED EEC IV, THIS STANDS FOR "ELECTRONIC ENGINE CONTROL, FOURTH GENERATION". HERE IS A LINK TO TEST OUT THIS SYSTEM.
http://check-engine-light-codes.blogspot.com/2006/04/ford-1985-95-obd1-code-self-retrieval.html
Nov 06, 2009 | 1993 Lincoln Continental
I cannot remove the bottom of my cd player. I want to hang it on the wall
Turn the system upside-down and look at the bottom of the stand. It should have arrows saying "Release." Pull the stand in the direction of the arrows, and it should come off.
Oct 03, 2009 | GPX HM3817DT Shelf System
Hartford vr 150 z
It is probably the side stand switch
Oct 02, 2009 | 2002 Hartford VR 150Z
Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
DVD player do not turn on
My JBL Cinema ProPack 600 System is stuck in stand bye mode (amber light). Anybody know how to resolve this problem?
Feb 15, 2008 | JBL Cinema ProPack 600 System
Yamaha RX-V871 - 7.1 Home Theater Receiver Logo
44 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
