Question about Samsung Televison & Video
Samsung TV stuck on with picture and volume and no working controls on TV or remote
TV stuck on with picture and volume and no working controls on the TV or the remote. When you push buttons on the TV or the remote you get confirmation flashes from the red LED on the front of the TV but nothing changes.
    Top Expert:
  • Samsung Master
  • 73,619 Answers
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. Electro help
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Apr 21, 2014
How do i fix volume problem , i have samsung 46 inch lcd , picture working fine but no sound?
Hi is your television running through a foxtel box or something else that has volume control, If so you might have one or the other turned all the way down, turn both volumes up and control every thing through one remote control.....
Mar 15, 2016 | Samsung LN46B550 46 in. LCD HDTV
Volume intermittently increases all the way to 100 and cannot be controlled by the remote
This happens with some models. You can open the TV from the back and disconnect the connector for the side control board. You will only have control via the remote but your volume issue should be resolved.
Apr 12, 2014 | Samsung Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
I have a Samsung TV and no volume control works other than the Samsung remote. Is there a Universal Remote that can learn the Samsung TV Volume control?
check the codes on any universal remote to see if its compatiable with your samsung tv code which is supplied
Jun 21, 2009 | Televison & Video
LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Apr 10, 2009 | LG 32LB9D TV
The volume control is stuck
you didn't mention even using the remote. any way if it does not control even doing manualy or with remote control contact the dealer of you tv and discuss the problem. This could happen now a days LCD tv's has a program to operate. i suspended the program of your tv has reset.
Mar 26, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Televison & Video Logo
109 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
