Question about Ferrari High Back Booster Car Seat
Ferrari carseat back straps adjustment??? - Ferrari High Back Booster Car Seat
2 Suggested Answers
mwawinyirend
SOURCE: How do I remove the head rest from the ferrari high back booster?
I have the same problem. I want to remove the headrest so that i can wash the cover. my car seat looks like the one on this pagehttp://4.bp.blogspot.com/_MrQjKKC90Ik/TKXqOfzH-cI/AAAAAAAAEic/Oe3gQmMldtM/s1600/ferrari+2.jpg
I cant load this page http://www.coscojuvenile.com/instructions.asp
Posted on Oct 31, 2012
Cant figure out how straps go back on carseat since I washed it? its the brown and tan high back with tilt...omgoodness I cant believe I have done this please help!!!!!!
This isn't a product available in the UK so we're unable to assist with your enquiry. Could you let us know what country you're in so we can direct you to the appropriate customer care team?
Aug 04, 2012 | Safety 1st Baby Gear
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
Trying to adjust the child seatbelt harness higher in the carseat
I located my instruction manual for this carseat. It instructed me to turn the carseat over & located on the bottom are two metal brackets that lock the seatbelt harness. You just have to detach each metal bracket & pull through the bottom slots of the carseat, readjust each seatbelt to whatever level is necessary & push back through the bottom of the seat to lock securely. Thanks anyway for your help!
Apr 09, 2009 | Evenflo Baby Gear
Feb 26, 2009 | Ferrari High Back Booster
Car Seat Belt keeps getting stuck
check the adjustable strap then check the spring of the strap .
Feb 02, 2009 | Graco Quattro Tour Travel System
Evenflo journer
on the back of the carseat the are black plastic holders the straps go threw and there is a part in the middle that you push down and you pull the front staps to loosen or the back straps to tighten
Feb 17, 2008 | Evenflo Journey Premier Stroller
Strap Adjustments
Yes, Im sure you can find it in a department store or online store. Try target.com probably, they are called extension strap like this http://www.babyonthemove.co.nz/shop/Car+Seats/Carseat+Accessories/600mm+Extension+Strap.html?id=akv7atuH
Jan 22, 2008 | Cosco Summit 22260 - Bouncing Sheep
Carseat straps
You can move it by pushing down on the flexible tab part of the seat base just above the box, but you don't need to move it at all in order to adjust the straps.
In order to move the straps I remove the clip side (the opposite side of the box), this removes in the same manner as the black box side, you just push down onthe flexible tab on the base; and run it through backwards, slide it into the next hole up, to make it larger run it back through the holes and click it back into the base in the back of the seat. This can all be done without disabling, The clip in the front of the seat must be unfastened but it will all fit through the holes in the seat to adjust the straps.
Oct 04, 2007 | Evenflo Embrace - Rainforest
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Ferrari High Back Booster Car Seat Logo
Top Ferrari Baby Gear Experts
Dorel UK
Dorel UK
Are you a Ferrari Baby Gear Expert? Answer questions, earn points and help others
