Question about Zanussi Washing Machines
Not heating up
Zanussi ZWI71201 WA machine will not heat up otherwise everything else ok
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Try changing element if electric or if gas check pilot
Posted on Apr 21, 2014
  • 353 Answers
SOURCE: replacing heating element in washing machine
check side of machine,if it has a line going down side then u split the cab in 2 remove back piece and all will be revealed
Posted on Dec 21, 2009
COXY
  • 76 Answers
SOURCE: Zanussi Fla1201w not heating water
Sounds like you need a new heater. test it with a meter to see if its open circuite. the programme will not move round if the heater is gone. heater cost around 20 GBP. to have an engineer do it will cost around 50 GBP.
Posted on Nov 19, 2007
  • 209 Answers
SOURCE: Heating element Zanussi washing machine
remove the back, the element is at the bottom of the drum tis maybe a split cabinet, where the lid comes off the it splits down the middle like cracking an egg, loads of screws, hard to describe, also 2 at bottom at the side in the middle, behind 2 plastic lugs, when removed the back half of the cabinet comes away, not an easy job until you have seen it done if you really are stuck try and send me an e mail address and i will send you a drawing, then you will see its easy, i am an engineer of 20 years and done loads, its easy job to do once you know how to split the cabinet
Posted on Oct 07, 2007
barkencoa
  • 3463 Answers
SOURCE: HI, My zanussi zwf1221w Washing Machine doesn't
You need to check to see if you are gettring a supply to the element when it is at the heating stage, you will need a meter to do this.
If no supply, then could be a faulty thermostat or thermistor, other wise it could be a faulty programmer or control unit.
Hope this helps
Posted on Feb 11, 2010
  • 174 Answers
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
Posted on Nov 10, 2010
Zanussi FJ1214 Washing Machine won't agitate but spins
Sounds like gearbox or check if a belt has came off or slipping underneath.
Nov 01, 2014 | Zanussi Washing Machines
I bought a Zanussi ZKG2105 less than two years ago and all of a sudden it would not switch on. Checked everything, the fuse, the power outlet and the filters, everything seems fine but it just would
Try replacing the temperature sending unit in the back of it. Just 2 screws hold it on and 2 wires connected to it. It's just a round button style with a plate and 2 holes for screws to attach it. If it's bad, you'll get no heat to the element. Runs but no heat tells you this is the problem.
Sep 09, 2014 | Zanussi Washing Machines
Zanussi zdc37200w dryer no heat
there is an ntc probe at the bottom of the machine attached to a hose , have you found this ? it may need replacing .
Jan 23, 2013 | Washing Machines
I am put fan and processor gum wa not
Dear,
you need to get a compound called heat resistive compound for this. Otherwise your processor will be heated a lot and will cause restarting of pc after heating...
best of luck!
Mar 07, 2012 | Biostar G31-M7 TE Motherboard
Zanussi tumble drier is not heating up to dry clothes , but is working OK otherwise
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Dryers
My Zanussi zwf16070 is not heating up the water is the thermostat
Could be also check the heating element should messure 28/ 32 ohms on a multimeter if ok.....
Jun 19, 2010 | Zanussi ZWF1630 Front Load Washer
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Washing Machines Logo
63 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
