Home | Sharp | AL 1631 Grayscale Copier | SHARP AL1631 drum lig...
Sharp AL 1631 Grayscale Copier
Problem for Sharp AL 1631 Grayscale Copier
SHARP AL1631 drum light wont go off.
By jrickard on Jun 19, 2009
I replaced the drum and toner. When I restarted the machine the drum light stays on but now it will make NO copies. I have e-mailed sharp but have heard nothing from them yet. Does anyone know what the problem is that would be willing to share the answer? Thank you
Comments:
Jun 25, 2009
- Thank you, we tried that but couldn't put in a qty. (24) . It doesn't acknowledge us.
Jun 25, 2009
- We did not suceed the first 2 X But on the third attempt it WORKED!!!! Thank you so very much!!!
Sponsored Links
Best Solution
posted on Jun 23, 2009
Very Helpful)
angelus316
Rank: Wiz
Rating: 90%, 33 votes
you have to reset the drum code by doing the following
press clear / density select /clear / density select
select 24 and enter
7 and enter
restart copier and away you go
Comments:
Jun 25, 2009
- you are very welcome
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jun 28, 2009
Not Rated)
xptareq2000
Rank: Wiz  Sharp Expert
Rating: 78%, 415 votes
C-photo-c-photo then machine disply is blank then press page quantity key left two times and right four times then press printkey
and then 7
Comments:
Aug 19, 2009
- c photo c photo press 24 press print key press 7 press print key
power off your machine on again then omit drum signal make copy
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 1631 Grayscale Copier
Questions and Unsolved Problems for Sharp AL 1631 Grayscale Copier
Do you recommend Sharp AL 1631 Grayscale Copier?
Answer
Answer
I installed a fuser unit in my Sharp AL-1631 and change fuser warning did not go away. Is there a... (More)
Answer
My scanner lock is flashing but it's unlocked??
Answer
what's the most efficient way to communicate my sharp xe-a21s with my QuickBooks data file
Answer
The register says ppppppppp and the register is locked. What do we do?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL 1631 Grayscale Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 1467
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
