Question about Intermec 761B Portable Terminal
Intermec 761B - ITCScan dll issue
I keep getting the following error 'Make sure the ITCScan.dll is in the windows directory'.
I have checked the windows directory and the ITCScan.dll is present. I have tried replacing the dll, deleting it & then re-installing with no success.
I was just wondering if you have ever come across this issue before and know how to resolve it.
Thanking you in advance
Peter Quinn.
  • 244 Answers
Re: Intermec 761B - ITCScan dll issue
Copy and paste the ITScan.dll file to as follows
Please rate SOLVED if you like my solution.
Best regards,
Posted on Nov 05, 2007
0 characters
3 Points
CK71 stuck on Launching OS
Please try to Install OS through Intermec Smart System from - downloads
and try to install OS via WIFI connection
Note : Make sure about WIFI Connection & Battery Charging power of device
Aug 22, 2011 | Intermec CK71 Handheld Mobile Computer...
Deploying App (Post Deployment Error)
Under Windows CE 4.x series:
Look under here:
Motorola EMDK for .NET\v2.0\SDK\Smart Devices\wce400\armv4
for to copy to the PDA to install.
For Windows Mobile 5.x series:
Look under here:
Motorola EMDK for .NET\v2.0\SDK\Smart Devices\wce500\armv4i
Hopefully you won't get the error again. I personally just reference the dll under:
and have each symbol reference in my smart device deployment set to "local copy = true". Good day.
May 06, 2009 | Symbol MC9090 Barcode Scanner
Good day, I need the Intermec 4420 service manual, could you help me?
Contact Intermec Support at
Intermec Repair Center
13509 Southpoint Blvd. Suite 100
Charlotte, NC United States
Telephone: 800-755-5505
Intermec doesn't put service manuals on their website. You may run into issues if you are not Intermec service certified.
Billy Barcode
May 01, 2009 | Barcode Scanners
Keep getting error Cannot execute btcc.exe
If your device is registered at you should be able to dowload a firmware flash for the device. Follow the instructions and reflash the device. If this does not work the bluetooth radio could have malfunctioned.
Feb 11, 2009 | Intermec Barcode Scanners
Intermec CK30 Won't Display Desktop
The ck30 does not have a desktop. Press the green then orange key to access the system menu. Alt then escape will bring up the task manager.
Nov 27, 2008 | Intermec CK30
Intermec 751B problem after clean boot with iconnect
I had same problem with my Intermec CN3e after updating firmware OS. I also have updated the SSPB version (see it on intermec web site) and problem has been solved.
Nov 18, 2008 | Intermec 751 Barcode Scanner
Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Intermec 761B Portable Terminal Logo
1,122 people viewed this question
Top Intermec Barcode Scanners Experts
Brian Sullivan
Brian Sullivan
Are you an Intermec Barcode Scanner Expert? Answer questions, earn points and help others
