Question about LG Optimus L9
Lg 9 phone says"experiencing high heat" and then shuts off
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Buy a new battery for the phone, possibly been fried.. charging causes this
Posted on Apr 24, 2014
  • 91 Answers
Incorrect. New battery is not the cause. Whats causing this overheating on your phone could be the following:
1). You have too many open apps running in the background which makes the processor run at higher speeds; causing the phone to get hot.
2). Using 4G compared to WiFi, does increase the temperature of your phone. Therefore, use WiFi when available to prevent this.
3). Make sure you have all your settings off when not using.. For example... Bluetooth, GPS, 4G, Wifi, etc... Leaving this services running while not using them causes the phone to overheat.
4). If you run certain games that require a lot of physical memory, your phone will heat up.
5). Using your phone on hot environments.
6). Do not use your phone while charging.
Take note on this suggestions and will definitely improve your smartphone temperature.
Posted on Jul 11, 2014
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
Tip
Problems with LG EnV 9200 shutting off randomly.
This may not be a problem directly related to your phone. I was seeing this and took my phone to Verizon, When issuing a replacement phone, they took the SD card out to put it in the new phone and it did it again. The problem was related to the memory card, Not the phone . Tech also said that the battery causes this as well, because the battery is not flush with the phone. Try removing memory card first if you are experiencing this problem. Especially, if it seems to relate to pics or music.
on Sep 30, 2010 | LG enV3 VX9200 Cell Phone
Laptop lgr40
1. Stop Overclocking your CPU
2. Make sure your Heat Sink is placed properly above the processor
3. Clean the Processor fan, Heat Sink and other peripherals
4. Use High Speed fans
5. Use CPU Heat Sink Paste in the processor
6. Make sure your dint restrict the speed of CPU fan.
7. Use Additional Cooling Units
8. Check your SMPS
9. Use proper ventilation in your room
10. Shut down your computer at least two hour a day
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which cause of heat problems
Jul 03, 2013 | Computers & Internet
I have heard all the problems about the envy 3 shutting off. Mine will be a year next month. I bought 3 at the same time for my husband and son. The dont use theres to often and are not experiencing the...
Hello.
Sounds like you answered your own question.
With all the problems you are experiencing and the warranty ending soon, this is a good time to contact Verizon for a replacement phone.
In years past, when I experienced problems with a phone, there was very little hassle in customer service. They replaced my phone.
See if they can back up any data you have stored on the phone, if you haven't backed up. They will also replace any games, music, etc. that you have downloaded. They may need a list of them.
Hope this helps.
Oct 04, 2010 | LG enV VX9900 Cellular Phone
Hi - I have a LG 42LP1D, I have tuned the digital stations, but it only starts from Channel 10. So I am missing 1 - 9
Are there Digital stations at 2-9? I'd try a rescan to find all channels it sees. If you are getting TV from over the air antennea, then it might be since the switch over the channels you might have been receiving before are not strong enough now that they are digital. Some locations are experiencing this.
Nov 23, 2009 | LG 42LP1D 42 in. LCD HDTV
My LG Rumor randomly decides to shut itself off. I'll be sitting here wondering my phone hasn't rung and then I'll see that the stupid thing is off again!
Maybe u need 2 charge it fully a couple of times or turn on key guard if it was in your pocket or something like that. I cannot really tell if u do not specify more clearly what is wrong with it. Sorry
Jul 08, 2009 | LG RUMOR Cellular Phone
LG Dare locks while typing a text message.
I thought I had this problem too, but then I realized I was pressing the lock on the side of the phone. When holding the phone sideways to get the full keyboard, the phone rests on my pinky fingers so I can type with my thumbs, and the lock button is right where my left pinky finger hits the phone. Very inconvenient, but you just have to be aware of it, maybe change the way you cradle the phone while texting.
Jun 25, 2009 | LG Dare VX9700 Cell Phone
LG ENV2 shutting off
I just got mine a few weeks ago and it does the same exact thing (I didn't drop it, there is no water damage, I didn't understand the cause of it). I took it back to the Verizon store and I was told that the random shutting off like that is caused by having the phone outside being exposed to heat. He reset my phone back to factory settings and that did the trick for awhile (its hard for me to go to the pool and not have my phone exposed to the heat). There is no charge for them to reset the phone. Mine has started the random shutting off again back up
Jun 03, 2009 | LG enV VX9900 Cellular Phone
LG 9400 cell phone
take it back to verizon. unless your using a 2nd hand battery
Aug 31, 2008 | LG VX9400 Cellular Phone
Toaster Side wont 'start'
I would say the door interlock switch (or its mount or wiring) has failed.
This is to prevent it from running when the door is open.
It may be shut, but if the signal from the switch is not present, it will not run.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 04, 2008 | LG LTM9000 Microwave Oven
LG Optimus L9 Logo
94 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
