Question about Bosch Nexxt 300 Series WFMC2201UC
Apell washer dryer with a fault E13
Fault e13
SOURCE: Code E13
For a Bosch washing machine, Error 13 is pumping time exceeded. So, in general, the issue is pump related. Things to check would be if the pump is blocked (it can be cleaned out if you can get the service door in the front panel off), check the wiring connections to the pump, and check the drain hose to make sure it is not blocked.
Posted on Apr 02, 2008
  • 1294 Answers
SOURCE: E13 error- can't unlock the door
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Posted on Apr 08, 2009
Macmarkus
  • 2605 Answers
SOURCE: door locked and won't open
Hello and welcome to fixya. The "E13" error code on the WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" ) What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely. You haven`t mentioned if you`ve checked the pump...just hoses as you did mention. Anyway, here`s the most likely way to remedy a E13 code. **Unplug the washer from the wall or turn off the breaker before attempting any repairs** Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain ) Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Find a drill bit or small screwdriver that fits in the hole in the round door. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves). Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks. Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first. Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly. Thank you for coming to "fixya" and good luck. macmarkus :)
Posted on Jul 10, 2010
Macmarkus
  • 2605 Answers
SOURCE: My washer will not rinse. It shows an E13 error.
Hello, Welcome to FixYa. The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" ) Anyway, here`s the most likely way to remedy a E13 code. **Unplug the washer from the wall or turn off the breaker before attempting any repairs** Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain ) Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Find a drill bit or small screwdriver that fits in the hole in the round door. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves). Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks. Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first. Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly. Thank you for coming to "fixya" and good luck. Regards, Macmarkus :)
Posted on Oct 09, 2010
KevinWhite
  • 1902 Answers
SOURCE: Bosch E13 error on washer
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jul 30, 2011
Hoover washer dryer wd 9616c error code e13 and burning smell from the rear????
The automatically suggestted E13 guidance that the system posts referring to Bosch machines is irrelevant I'm afraid. On a Hoover, the message means "Faulty module connections. Check all connections between modules and associated wiring." The chances are that you have a partially dislodged connector on the main board, or on the connector that goes to the motor
Oct 14, 2015 | Hoover Washing Machines
Error code E:13
I thin E13 is motor error, I will check.
Sep 03, 2008 | Bosch Nexxt 300 Series WFMC2201UC
How can I fix my washer when it stops with an E13
E13 indicates your input voltage is to high
also can happen with faulty motor/ brushes
Jan 31, 2015 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
What is error code e13
Good Afternoon Friend,
I understand that you are receiving an E13 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E13 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Electrolux EW1000i Front Load Washer
Error code e13
Hello Mark Depner - Typically error code E13 indicates that the washer is detecting a water leak in tub or air leak in air bell. You will need to contact a professional to move forward accurately and verify where the leak is located.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
E13
Here the tips... support/t7599677-error_code_13
Apr 25, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Washer not draining and rinsing
Hello Wet Towels, well to be honest outside of the test program I have never seen a fault code E13. If it was an error E03 I would check my water to make sure it was turned on, the cold inlet hose wasn't pinched, or debre filling the filter screens in the hose or water valve. That is what the care and use says about E03. In the back of your owners manual it tells you what the fault means and how to correct it. If this doesn't work call for service to resolve your issue. Hope this helps.
Aug 10, 2008 | Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
317 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
