Question about Kitchen Ranges
Quigg double cooking plate
I'm trying to fix one for my neighbour but an lacking the schematics for it Cannot find them anywhere yet. Can anyone help me? I already changed the mosfet fga25n120 ibgt, so no more shorts. But it doesn't work yet.
5 Suggested Answers
  • 3 Answers
SOURCE: smell of neighbours cooking comes through hood fan! HELP!
It appears to me that each hood has a fan discharging air and odours into a common duct.
The only solution to me is to have a main exhaust fan at the very end of the duct continually sucking the air out of the duct.This way it will not allow the individual hood fans to pressurise the main duct,forcing the air to esape through the path of least resistance,which happens to be the neighboars hood.
It may be that such a fan is existent but switched off due to malfunction,or switched off for running costs reasons.
Posted on Sep 26, 2008
SOURCE: I have a powercom (VGD 1000 VA)online UPS.All
It sounds to me like you have a shorted cell in one of the batteries and the current limiting resistor on the charging side is out of tolerance (too low). Though it is more likely that they fail too high, they can go low in the event of overheating. I would check the resister with an ohm meter vs what is printed on it. It should usually be within 10 to 20% you can put one in series to limit the current, but you need a high current diode in parallel with it as no to limit the current to the inverter. I don't remember, but i think your model uses 2 12vdc batteries. You should replace all of its batteries and check the resister. Also, if there was a plastic insulator on the old mosfets you took off, you must have it on the new ones. this is to isolate the collector from ground. I home this helps,
Ryan
Posted on Apr 19, 2009
maxtreadmill
  • 832 Answers
SOURCE: Motor Controller Board Schematic
If you are the original owner the parts in residential settings is lifetime so call body-solid @ 1-800-556-3113 ext 520
Posted on Mar 02, 2010
  • 12 Answers
SOURCE: my adcom gfa5500 .most of its output mosfets are shorted.
i give you the schematic
Posted on Jun 25, 2015
I am trying to find a replacement part for a 24 Maytag Wall Oven, model CWG3100AAB. I am getting an F5 code, and I believe that means it is the ERC electronic control board.
Single/Double Wall Oven - Error Code/Message - F5 Error ...
www.maytag.com/...wall-oven...code...f5...code-f5-e0/PH7028/
MaytagHave a Maytag product question? Maytag's product help articles give answers to your frequently asked questions (FAQs).
Sep 30, 2015 | Maytag CWG3100AAB Wall Oven gas
I lost the userguide of my quigg ultrasonic cleaner, type SR 630.09. And i want to clean my watch and jewelry. Can anybody help me use this machine.
This Manual will give you the Information to get it working correctly again... Good Luck
http://www.manualswall.com/results.php?lang=en&search=MICRO+ONDE+QUIGG+MD+12801+USERS+GUIDE#.UWMt8VeRfAI
Apr 08, 2013 | Watches
Setting the oven to come on at a certain time
I have a neff u1722 but I think the settings are pretty much the same. To set a coming on time first press the button with side by side triangles on it until the symbol l->l flashes then rotate the plain button next to it to the length of time you want the food to cook for. After about 4 secs the normal time will come back on. Then press the side by side triangle button again until the symbol ->l flashes then with the plain button rotate again to set the time you want the food to be cooked for. Hope this works
Jan 16, 2009 | Neff U1421 Double circotherm Electric Oven
Fixing thermostat on oIder Hotpoint Double Oven
Hello, there is no fixing the thermostat although some of the older thermostats could be calibrated by using a very small flat head screwdriver in the shaft of the thermostat if there is no opening for a tiny screwdriver in the shaft then it cannot be calibrated. If you have to change the thermostat contact your local parts department have the model # handy if the original is not available ask about universal oven control replacement parts. Good Luck
Dec 21, 2008 | Zanussi ZDQ895 Electric Double Oven
Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have tracked down the problem to the main circuit board at the back, bottom of the machine. Transistor/FET Q9 has exploded. There was water at the bottom of the machine and the wiring in the vicinity of the nearby connector was wet.
This neighbour is in no financial position to be able to buy a new board, or get an official Hotpoint engineer to confirm what we already know. Anyone know where I can get a schematic diagram for the board?
Dec 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Smell of neighbours cooking comes through hood fan! HELP!
Mar 30, 2008 | Fantech SHL48 Insert Range Hood
George Foreman G5 Grill
With the unit unplugged, check the elements to see if one has become unseated. A gentle push should seat them. Some elements are plug in & can come unseated.
Jan 21, 2007 | George Foreman G5 Indoor Grill
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
