Question about MSI G31M3-L V2 Motherboard
Dead no power on
  • MSI Master
  • 3,320 Answers
Check all connections particularly the power on switch jumpers.
Posted on Apr 22, 2014
1995 Geo prizm, no power to fuse 10 in fuse box under left side steering column ,no power to distributor or fuel injectors,were does power come from
dead engine,
do head lamps work?
on a dead car, dead engine, all power comes from the main car battery. and all power feeds are fused.
if fuses blow, no power to that feed.
if the battery is dead so will be the head lamps and hand lamps
do not take a key top work (a safety feature)
this car is toyota corolla. (with geo stickers)
how do you know power is missing from F10?
you used a voltmeter there? or test lamp? how>?
there were 2 engines, 4A and 7AFE engines.
ill guess and answer for 4AFE engine
Fuse 10 is not a number its the current rating of the fuse.
and is maked (you didnt show a photo of fuse, nor where it is)
is marked IGN
now ill answer with the schematic. (makes it 10x more easy)
now power feeds IGN fuse, from the key switch
if that switch works the power come to it from
AM2 fuse
If AM2 is dead then the battery is dead. or
the battery ground is bad.
or the battery lugs are rusty
or the battery is only discharged, so charge it.
or jumper cable start car like you see the AAA tow truck man do.
Jul 25, 2016 | 1995 Geo Prizm
I have a 2011 Jeep Liberty has the infinity amp in it I put aftermarket radio in it and no sound at all
fuses are blown
if the radio has 12vdc to all power pins, then it has power.
if grounded too.
if dead in all modes!now, the head is dead (AMP dead at least)
im assuming at least 4 speakers and not all 4 can magically die one day. (never seen in 50 years of electronics that case)
get a volt meter, and learn to use it?
the meter is $10 at walfart. 12vdc is good. 0v is bad.
the head and amp has a manual.
most modern head the Red wire is radio power.
so is the radio part dead. dial dead, cant scan FM,or AM.
if totally dead radio side, no sign of ANY life. (not just sound)
that is a bad fuse.
if the radio is scanning, then the amp sides is dead.
check the power to the amp side.
is amp separate> you never said if its a all in one radio or 2 parts.
Jun 05, 2015 | 2011 Jeep Liberty
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
Intel desktop d845epi in the motherboard is not powering on.plz send a solve procedure.urgent
computer not power on can be caused by 2 thing, first is your power supply was dead, and the second is your motherboard was broken
try to connect another power supply, if your motherboard can power on it mean your power supply was dead if still not power on it mean your motherboard was dead, change the motherboard with new one
Mar 18, 2011 | Intel Desktop Board D845EPI Motherboard
My flatscreen monitor (HP w19b) kept powering down. I would push the on button, and it would go on then power down after 10 seconds. This morning it wouldn't go on at all for about 1/2 hour, then started...
Hi sir, try to check for possible leaking or bloated filter capacitor in power supply board. That symptom might be caused by insufficient current draw from power supply source. Try to check sir. Maybe it could help. Thanks!
Feb 14, 2018 | HP W19b LCD Monitor
Computer will not power up. power is on bup computer is dead.
Take your computer to any computer-store, and get them to trouble-shoot, i.e., dead power-supply, or dead motherboard, or broken ON/OFF switch, or loose cable inside the computer.
May 28, 2010 | Computers & Internet
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
May 16, 2010 | Dell Dimension 4400 Power Supply ** FREE...
Mobo does not power up Dead cpu dead mobo?
A dead CPU will not hinder a board from powering up. The board is unlikely to POST. However, you should heard attempts at powering up and immediate shutdown. Or, you will see the PSU comes on but system not boot.
No mobo, but, CPU.
If no failed attempts at boot, no indicator lights, then you have either a failed power supply or DEAD motherboard.
Good luck
Sep 27, 2009 | Fujitsu Siemens Computers & Internet
Printer dead, no lights, not powering up at all
your power supply is probably dead you will have to replace it
Jul 19, 2009 | Lexmark X8350 All-In-One InkJet Printer
MSI G31M3-L V2 Motherboard Logo
52 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
