Question about Honeywell 3820 Computers & Internet
Is not scanning
Have tried resetting by unplugging system; have removed the battery and reinstalled battery. The green light on the charging station does not light up except for an occasional flicker.
SOURCE: Dead laptop
where is reset button
Posted on Jan 18, 2008
  • 6 Answers
SOURCE: Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Posted on Apr 19, 2008
  • 14 Answers
SOURCE: Makita BR1815 li-ion batteries won't charge
your batteries are toast;must replace
Posted on Aug 02, 2009
SOURCE: Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Posted on Dec 17, 2009
SOURCE: Logitech DInovo Edge: When I charge the keyboard
It looks to me like Logitech changed the design a bit. I found no such "CAP", however the problem did in fact lie in the same spot under the sleep button. I found a flat cable that had 6 jumper wires running through it to be the culprit. The cable was made too big, so they bent it to make it fit thus damaging it. I'm going to have to replace it, but just from playing with it a little I got my keyboard to turn on advertising a full charge and when I set it on the base I get a green light off happiness.
Posted on Jul 09, 2010
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Not used my netbook for a week it was fine when i turned it off now when i plug adapter in green light comes on but nothing happens if i unplug it then green light turns to orangy colour i plug it straight...
Unplug the charger, remove battery and then keep pressing the power button for 30 sec. Then wait for one minute, load the battery and then try to switch ON.
Apr 26, 2014 | Samsung N150 (36725723009) Netbook
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
I bought a psyclone essentials Wii charge station with 2 batteries PX6522. However, when I lay the batteries down on the inductive charging pad, nothing lights up (not the red for charging or green for...
I know this is an old post, and you likely don't need the answer anymore, but It appears that the programming in the induction pad can get screwed up and it won't actually detect that the batteries are there. By unplugging the station and leaving it unplugged for a bit, then plugging it back in you can normally reset the pad and get it to detect (and charge) the batteries again.
Jan 12, 2011 | Video Game Consoles & Games
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
My AT&T E5921 5.8 GHz - Cordless Phone handset shows "Connecting". I have tried 2 new batteries and resetting the base station as per the instruction manual without success. The charging...
I don't know if you have tried this but clearing all handsets from the base (so there are non) finish setting it for non and then start over as per manual.
Before you start re-setting them -
!st, unplug (for 20 seconds) then re-plug in Batteries from all hand sets. You may want to unplug the main Base as well at the same time you do the others.
My system has had problems that just unplugging and re-plug in the battery has solved. (It was flashing like someone was on it but if I picked it up there was a dial tone)
Hope this works for you :-)
Sep 08, 2017 | AT&T E5921 5.8 GHz - Cordless Phone
Dell D610: Does not charge w/ any a-c adapter/battery pack.
This seems to be a shot in the charging circuit of the motherboard. If in warranty call Dell hardware supoprt and they will do the needful in warranty. If the warranty is out try a local technician and maybe they can repair the board.
Aug 10, 2009 | Dell Latitude D610 Notebook
Green light stuck on.
Left the ck30 powered off and removed the battery. Replaced the battery with a fully charged one. After a couple hours rebooted the ck30 and it booted normally. My ck30 was tied to the AS400 system. I think this may have been a factor with this issue.
Sep 12, 2008 | Intermec CK30
Computers & Internet Logo
51 people viewed this question
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
