Question about Danby Refrigerators
DFF1144W fridge stopped working efficiently
  • 884 Answers
Check condenser is clear and clean, and fan working. If all else as should be, suspect becoming short of refrigerant
Posted on Apr 30, 2014
Disable auto defrost
Freezer Repair Help - Free troubleshooting and videos ...
www.repairclinic.com/RepairHelp/Freezer-Repair-Help
This video provides information on how a freezer works and offers troubleshooting... Frigidaire Upright Freezer Disassembly - Freezer Repair Help · Repairing a ...
Aug 03, 2015 | Danby DFF1144W Top Freezer Refrigerator
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
How to remove a side panel to fix a dent?
You can't. The body panel is made from a single sheet of metal.
Aug 05, 2014 | Danby DFF1144W Top Freezer Refrigerator
Hi, i have an Electrolux ER7198S side-by-side fridge. there are not cooling enough.. someday cool someday not, may i know why and how to slove the problem? thanks
Make sure there is about 3 inches of clearance behind the fridge from the wall. Move the fridge away and check that the condenser coils are not covered heavily in dust. This can reduce the fridges efficiency.
You may also want to open and check the inside panel of the fridge to observe the evaporator coils and defrost tubes. If those tubes are burnt out (they are basically long light bulbs) you may get a build up of frost and ice that stops the flow of air thought the evaporator. This will cause the fridge to become warmer, up until complete failure.
Jun 01, 2012 | Refrigerators
We have an older model Danby D730, it is freezing on the back part inside of the fridge. We realize there is no more around, is there anything that we can do to save it.
Sounds like defrost problem. Could be fan motor, Defrost timer,or defrost heater. Try turning off for 8hr to melt ice then turn back on.If it runs and maintains temp for 24hr check and repair defrost Problem.
Sep 06, 2010 | Danby 11.4 cu. ft. Frost Free Generation...
Bottom freezer has stopped working efficiently as a freezer (now fridge temp) all food defrosted, . Previous to this freezer was icing up, ice would fall out when you opened up the drawer. Please help
these machines use thermosistor a solid state temperature reactive transistor devices.
they do not seem to continue to work well. please check to see if the refrigerator is in warranty or, return it if you can or, you can join the class action suit against LG
Jul 31, 2010 | LG LRFD25850 French Door Refrigerator
I have a 1990 Carver Santego boat and it has it's original u-line ice maker on board. This year I noticed that the ice maker was still staying very cold but stopped making ice. My husband checked to make...
as the fridge gets older the gas gets less efficient so regasing the unit may work, but, due to its age, you may find replacement more cost effective...and more efficient.
Jun 17, 2010 | U-Line Icemaker
How much tempature in the fridge should be to keep milk ok
33F - 40F (1C - 4C)
37F is default setting in most refrigerators.
Dec 18, 2009 | Danby DFF1144W Top Freezer Refrigerator
Ice maker not working
Hello bnelson488,
Since the ice maker is erationally starting and stopping at it's own leisure.
1.We must first try to turn off the fridge.
2.unplug it or if you can not reach the plug you can turn off the breaker to the fridge also, for 5 minutes!
After this you restart the fridge and see if the system reset it self.
This is a common way to reset some units!
If nothing works then perhaps the ice maker needs to be replaced.
How old the fridge?
Let me know how it works and if you have any questions.
Please remember to give a rating before you finish..
bless you
Huuum.
Here is an interesting article I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Sep 04, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Open Questions:
Danby Refrig DFFC1WDB, two years old, in my vacation home that I visit one weekend a month. Lights flashing, power cycled (after req'd 5 mins). Discovered coils were packed with ice. See below: 1.) Danby Refrigerator DFFC1WDB, about two years old, in my vacation home that I visit one weekend a month 2.) Never defrosted it manually before (i.e. turned off and left to defrost) 3.) For some time I noticed the light inside the fridge was flashing, but the refrigerator seemed to be cooling okay and the manual says nothing about what the flashing light means. I attributed it to a power failure and the flashing stops once the unit is unplugged and plugged back in (power cycled) after 5 minutes or so. 4.) This visit I noticed the flashing lights again and that the freezer was cold (it was heavily loaded) but fridge was barely cool. I power cycled the fridge (allowing 5 minutes) and the flashing stopped but I was concerned about the issue and threw out some food. 5.) I unplugged the unit again and removed everything from the freezer. I noticed a thick coating of ice on the freezer back wall. I used a hair dryer to melt this coating of ice and then realized that the coils behind this wall must be covered in ice. I removed the back wall exposing the coils and discovered that I was correct: The coils were completely covered/packed with ice, so I greatly sped up the melting process with the hair dryer. After all, I had food sitting in coolers with ice and wanted to return it to the freezer and fridge asap. 6.) Once all the ice was gone I left the freezer open for a while for the coils and assembly to cool (since I had used a hair dryer to melt away the ice pack) 7.) I set the freezer and fridge to their coldest settings and plugged it back in. The lights do not flash when I plugged it back in. The compressor (I assume) ran for a while (the fan in the freezer ran also), and during this time I heard the unit lightly buzzing (with life), and then it stopped. But it seemed to have quite a way to go when it stopped and the freezer and fridge were not nearly cold enough at that point. I surmised that it might be entering one of its periodic defrosting periods, but after quite a while of waiting it still hadn't started running again so I power cycled the unit again and again the compressor/fan ran for a while and then stopped. It just doesn't seem to be starting on its own unless I power cycle it (waiting the required 5 minutes before plugging it back in.) At this point I don't have confidence that it is cooling well enough to keep my food fresh (and frozen). 8.) What do you think could be wrong? It certainly seems reasonable that the part/system responsible for periodically defrosting the coils may have failed. But since the unit is completely defrosted now, why does the unit only run for a short time after unplugging/replugging and never run again?
Jun 10, 2018 | Danby Refrigerators
Refrigerators Logo
46 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
