Question about Becker Car Audio & Video
I NEED WIRING DIAG FOR 6502/4040
Hi I have a repair kit for my care radio/amp, however the kit wiring is slightly different to the original. can anyone supply me with a wiring diagram or cct diagram of the 6502/4040 Sister PCB.
  • Vince Millard
    Vince Millard Apr 21, 2014
    The unit is the UK version, with round pins in the main wiring socket.
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Posted on Apr 15, 2008
  • 149 Answers
SOURCE: Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
Posted on May 21, 2009
SOURCE: I NEED FREE FACTORY RADIO WIRING DIAGRAM
I have a 1991 honda accord radio problem can you HELPme
Posted on Jun 21, 2009
emissionwiz
  • 76630 Answers
SOURCE: 94' plymouth voyager care stereo wiring diagram needed
1994 Plymouth Voyager Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Violet/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Posted on Jul 05, 2009
  • 20 Answers
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
Posted on Aug 11, 2009
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
Jan 03, 2015 | 1998 Ford Ranger
Radio Installation
You can buy a kit with an adapter plug...easiest way to install a new deck.
Watch out when you insert the new deck into the original hole...wires pinch, short out dash, or lighting issues will occur if you are not careful
Mar 10, 2014 | 1990 Mercury Cougar
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
GS5SHAXLBo1 whirlpool start relay is different on mine , i called whirlpool they told me mine was a producation start relay and now they a a replace kit wiring is different , do you know anything about...
they told you correct . i looked your model and the org # subs to the kit 8201786 / i use these kits for many brands and what is in the kit is 2 start relays and 2 over loads and instructions an diag .. it's not a hard job . when removing the old relay read the # and see if it matches one of the new one and if so thats the one to use . if neither one matches then the brand of compressor will tell you which one to use . just read ite destructions before installing relay kit and if you remove any wires make a diag of where the were so you can reinstall them correctly.. rule # 1 its hard to back up without a road .. mm hope this helped mm feed back please ..
Dec 11, 2010 | Whirlpool GS5SHAXN Side by Side...
I have a 92 ford probe and im trying to install a
Have you removed the original connector from you original stereo? If you still have the original connector in place you can get a new connector from the Ford dealer that will plug into your existing wiring and into your new deck. Ford connections are unique to Ford and you need to adapt them for this application.
Take the car and deck to the dealer and tell them what you need. Everything just plugs in and your original amp and speakers in the car will work.
Having said that there was an adapter available at Wal Mart of all places that did work. You may want to check there.
If you have removed the original connector then you need a wiring diagram.
1992 Ford Probe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Red
Radio Switched 12V+ Wire: Blue/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Light Green/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Orange
Left Front Speaker Wire (-): Blue/Black
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Green/Orange
Left Rear Speaker Wire (-): Green/Red
Right Rear Speaker Wire (+): Green/Blue
Right Rear Speaker Wire (-): Green
The amp is located under the rear passenger side window. You need to remove the plastic side wall to expose it if you need access there. You can trace the wiring if needed.
Under the front bottom edge of the rear seat are clips holding the seat in place. Open the clips and the seat lifts off. You can then get to the amp as needed.
Mar 12, 2010 | 1992 Ford Probe
Replace stereo
If you have the stereo, the easiest way will be to get a Haynes repair manual on your vehicle so you have directions for opening the dashboard, if you haven't figured that part out. Next you'll want to go to walmart or some retailer that sells adapter kits and pick up an adapter mounting kit and wiring connection. This will allow you to use the original wiring harness with your new radio. The adapter for the radio it self may not be needed so check first. If the New radio has a cover plate attachment it may not need an adapter. Most Chryslers do need one and some of the imports but not all. Good Luck
Feb 21, 2010 | 2001 Kia Sephia
How to bypass the amp 95 mustang
The amp is under the driver's seat, but you can bypass it using a wiring kit from any local car audio place. It is an installation kit for any aftermarket stereo and should include instructions on how to use the kit with or without the factory amp.
Jan 14, 2010 | 1995 Ford Mustang
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Pink
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
Mar 19, 2009 | 1986 Honda Civic
Scosche - Aftermarket In-Dash Installation Kit questions
The radio should have come with its own wiring harness as well. The install kit will have a wiring harness that connects to the factory harness the original radio is connected to. You need the Kenwood harness and match the colors of the harness to the colors on the install kit harness. They should be crimped to make sure you have a solid connection and do not let any loose wires hang out anywhere. Then it is a good idea to use electrical tape and insulate each wire, then tape them all together for easier installation.
If you do not understand how to do this, you really should take it to someplace that installs radios, they can do it quickly and easily. No worries then about if you have made any mistakes. I have seen many a radio in my shop needing repair from people who thought it was easy to install a radio, but didn't really know how to do it. One mistake can end up costing more than buying a new radio.
let me know if you need any more help.
Dave
Jul 06, 2008 | Car Audio & Video
Car Audio & Video Logo
32 people viewed this question
Top Becker Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you a Becker Car Audio and Video Expert? Answer questions, earn points and help others
