Question about Karcher Garden
Mains cable on kb3030b - Karcher Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
True!.. more info plz
Posted on May 15, 2014
How to get the 5E error off my display on my kenmore microwave
fix it.
SE Shorted key 1. Check if cable of keypad has been inserted into connector of main PCB. 2. Check for short between main PCB and connector or keypad and cable. 3. If there is not a problem with connector on main PCB and cable of keypad, replace the main PCB.
Jan 22, 2016 | Kenmore Microwave Ovens
Connection cable screw broken in side tv
the main board will need replacement as the cable input is an integral part of the main board. You can get the main board from www.tvcircuitboards.com
Mar 01, 2013 | Coby TF-TV3217 32 in. LCD TV
What power supply connector will work with the ms8137c motherboard (aka, 20 + 4 pin)
Ahem, you just posted 20 + 4-pin.
That means it can be a 20-pin ATX main power cable, OR a 24-pin ATX main power cable.
Most power supply's now have a 20 + 4-pin power cable.
Use the 20-pin connector, or add the additional 4-pin connector, to make a 24-pin ATX main power cable.
Example.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
In direct answer to your question, however, it uses a 20-pin ATX main power cable.
For additional questions post in a Comment.
Regards,
joecoolvette
Jun 17, 2012 | Matsonic MS8137C Motherboard
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
I have a 20pin power supply adapter that reduceses to a(p8) 6wire&(p9)6wire plug that plugs into the mother board of my system.
Understandable.
A 20-pin ATX main power cable, is converted into two 6-pin AT main power cables, by that adapter.
20-pin ATX main power cable, and it's respective connector,
6-pin AT main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
As I'm sure you are aware, the color code of the insulation of those power wires, deems what Voltage they are.
Let's look at charts that compare the older AT main power cable connector, and power wires, to the newer ATX main power cable, and it's power wires,
http://en.wikipedia.org/wiki/Computer_power_supply
Scroll towards the bottom of the page, and look at the comparison charts under the heading - Wiring Diagrams
Now if you would, post back in a Comment, as to what the actual problem is.
Aug 01, 2010 | Computers & Internet
I have been using a KB3030B electric pressure washer to clean patio and have notice oil leaking from bottom of casing. Don,t know where its coming from nor what to do
The pump has a section with pistons that must have oil. The oil/piston housing is between the motor and the water portion of the pump. Some seals, somewhere are leaking. If you run it without oil it will destroy itself. You must get it fixed and I would do so before using it again.
Jun 10, 2009 | Karcher K2.26 Electric Power Washer
Part # for aspire 5043 motherboard
There are a few motherboard this series:
MB.AA101.001RF - Refurbished Main Board AB2 V128 w/MDM&Cable
MB.AA101.002RF - Refurbished Main Board AB2 V64 w/MDM&Cable
MB.ADX01.001RF - Refurbished Main Board AB2.UMA w/MDM/Cable/RTC
MB.ADX01.001 - Main Board Ab2 UMA w/Mdm/Cable/Rtc - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.001 - Main Board Ab2 V128 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.002 - Main Board Ab2 V64 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
www.acerparts.com
other guy asked for aspire 5100 motherboard, look here
http://www.zandparts.com/acer/index.php?cPath=40886_40887_40929_41356
Nov 22, 2008 | Acer Aspire 5100 Notebook
Main Alternator Output Cable
the main alternator cable usually runs from the starter where that is fed from battery.if you take cable off a motor factor will usually make one like the old one.hope this helps
Oct 29, 2008 | 1998 Ford Escort
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
