Question about Maytag MAV8757AW Top Load Washer
Maytag top loader will not drain all the water out of cloth during the spin cycle
    Champion:
  • 216 Answers
Belt tensioner idler pulley out of adjustment or damaged. or belt is worn out. belt is at bottom of machine and if you remove lower front cover, you can run the machine through a cycle and see the problem. my pulley fell off the shaft was on the ground and I had to replace the assembly.
Posted on Apr 21, 2014
Buffalo12980
  • 625 Answers
SOURCE: Maytag Atlantis 7600 spin cycle (top load)
the maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Posted on Sep 05, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
docjohn174
  • 943 Answers
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
  • 79 Answers
SOURCE: Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Posted on May 23, 2009
I have a GE Eterna top loader washer. It appears that is not spinning during spin cycle (damp clothes and softener not dispensed). Spin cycle runs with no load. How can I troubleshoot further?
Perhaps you machine is full of water and therefore restricted by the excess water in the tub, perhaps try draining the machine first then try again. it could be that your pump in ineffective .
Sep 19, 2016 | GE Washing Machines
I have a Maytag Bravos top loader washer and it seems to agitate during the washing phase but when it comes to the spin cycle the water drains but the clothes are still soaked at the end of the cycle, as...
This happens to me to. It is because it believes it has gone out of balance and has stopped and gone ahead and timed out making you think it has completed it's cycle. I do not have a solution to this other that I am thinking of chucking this washing machine out the door and buying an older machine.
Nov 20, 2012 | Washing Machines
DC Code on my maytag top loader washer comes on during the spin cycle and wont drain the water sears has been out over 5 times in 5 years to rebuild this machine everytime
Below is a link to a service buletin from Maytag stating the reasons for the DC Error, It's a balance issue and could require a software update to the electronics
Link:
Mar 07, 2012 | Maytag Neptune Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Maytag top loader washing machine
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV8757AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
