Smeg WM72141BK LEDs flashing 4 times
Our Smeg WM72141BK washing machine won't work and the LEDs are flashing 4 times. It doesn't say in the manual what 4 flashes means so was wondering if anyone knows what the failure is please?
    Champion:
  • 216 Answers
E4 is water temperature probe short or interrupted.
Posted on Apr 21, 2014
  • 1294 Answers
SOURCE: washer whilst washing keeps flashing up with E90
Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Posted on Jan 01, 2008
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
  • 3 Answers
SOURCE: E21 is flashing on the screen what does this mean?
E21 indicates that water is not draining from the machine fast enough. This can be caused by a kink in the drain hose, a problem with the pump or a problem with the pressure sensor.
On my washer, there's a copy of the service manual inside the machine - remove two screws in the back and take off the top. The manual includes the error codes and the steps to take.
Posted on Nov 18, 2009
richroth
  • 9472 Answers
SOURCE: My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Posted on Oct 16, 2012
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fills up then won't agitate and these LEDs light up!! Some sort of code maybe ??
sounds like an error code have you looked in the manual also with smart drives you shouldnt turn the powe off at the wall because the computer needs to be on all the time to keep it warm
Feb 08, 2013 | Washing Machines
Smeg washing machine stuck on pause
If the machine won't start then it will most likely be the door latch that is at fault.
Mar 12, 2012 | Smeg WDI12 Front Load Washer / Dryer
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
My SMEG S800 freestanding washing machine does not spin
Replace the mainboard of the unit.
(CCU)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Washing Machines
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
