Logitech z-2300 crossover location
Hello, I'd like to reduce crossover limit of sattelites and don't know where it is, could someone help with it?
My satellite speakers are no longer working, logitech do not issue replacement satellites. Do you know if their is a way to use alternative sattelites with the subwoofer?
the back of the sub has 2 rca connections for left and right speakers so all you have to do is either find satellites that use rca connections or find or make your own "clip-on" or detachable wire to rca connection.
Dec 24, 2010 | Logitech Z-2300 Computer Speakers
Can I turn the Logitech z-2300 to a 4.1 speaker system?
You will need a separate pair of powered speakers to do that, plugged separately. The quality of the sound will remain the same on the front ones, the overall quality will depend on the new ones.
Jul 17, 2010 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Feb 05, 2010 | Logitech Z-2300 Computer Speakers
Hello no deep bass
set crossover setting to 80.
Aug 23, 2009 | Audio Players & Recorders
Travelmate 4000 memory upgrade
Usually the system board will have problems with the 533 Mhz. You will get errors and/or may not come up at all.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 13, 2008 | Acer TravelMate 2300 Notebook
Wired remote bass control knobs
I'm wanting to know the same thing... But be careful on the pin out of the control you get.
I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
I have tools to crimp an end... Just can't figure out the color pin out.
Apr 16, 2008 | Car Audio & Video
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
41 people viewed this question
 Grubhead
Grubhead
