Question about OKI C5200n Laser Printer
How do I replace the image drum(s) in the OKI c5200 printer?
  • 3 Answers
You're going to have to buy a new one. Unfortunatelly you can't replace just the drum. There are "after-market" drums for some OKI's so you might want to look into that.
Posted on Jun 19, 2009
Http://printerdoctor.com/okidrumkit.htm
Posted on Jun 23, 2009
  • senoka Jun 23, 2009
    Kit to rebuild drum for Oki ® c3200 and from c5100 to c5800 series printers
4 Suggested Answers
Niraj Limbu
  • 183 Answers
SOURCE: k image drum
Go to
menu>Configure Device>Print Quality>select Full calibrate now
once it's completed then run following action:
Menu>Configure Device>Reset>Reset Supplies>New transfer kit>yes
you are done but it works if there still remaining bit transfer kit if its run out then not gonna work.
Good luck and rate all answers.
Posted on Mar 31, 2009
SOURCE: How do I find out the life left on the drum for a
Push the menu button on the C5200 Printer. Pust it twice or until you see Usage Menu on the LCD screen. Once you see it, press enter. Press menu button to cycle through the various details for each item in your printer. You will see toner life and drum life for each color and black as well. You will also see Fuser life and page counts and much more.
Posted on Jan 05, 2010
  • 97 Answers
SOURCE: OKI image drum issue
Try this:
1) Power on printer while holding both the + & - buttons simultaneously; release when "Okiuser" is displayed.
2) Press + or - until "Engine Diag" Mode is displayed; press Enter and Diagnostic Mode xx.xx.xx will be displayed
3) Press and hold both Enter & On-line simultaneously until Eng Diag Level3 is displayed
4) Press + or - until Local Parameter Set is displayed; release and press Enter
5) Press + or - until it displays Factory Mode; if it displays Factory Mode Twice with an asterisk next to one then it is in Factory Mode; Press Enter, Press + or - until it displays Factory Mode & Shipping Mode on the display; then press and hold On-line & Cancel simultaneously; when it stops blinking an asterisk should be displayed next to Shipping Mode, which becomes the default mode.
6) Power printer off then on to complete the procedure.
Posted on Mar 29, 2010
Why can't I use a toner and drum set from an OKI c5250 in an OKI c5200
While the drum units may appear the same, chances are Okidata puts a different chip on it that makes in incompatible. The C5200 will use drums from a C5150. The C5250 appears to use different supplies.
Sep 14, 2014 | OKI C5250n Printer
Why is oki c5200 streaking
Usually streaking on that model means it's time to replace one or all of the drum units.
Aug 26, 2014 | OKI C5200n Laser Printer
Oki c5200 alignment
often a drum unit will go bad causing misalignment of just one color. print the demo page and that will help you diagnose what one of the 4 colors is off and replace only that one drum unit
Jul 01, 2014 | OKI C5200 Color Laser Printer
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
How do i clean the print heads on a oki c5200
With the top cover open, gently wipe the LED head(s) with the lens cleaner pad supplied with replacement toner cartridges. A soft, lint-free cloth with some isopropyl alcohol (rubbing alcohol)** can also be used.As the last step before closing the cover when replacing a toner cartridge or an image drum.
If you are experience poor print quality, including
- longitudinal white stripes or fading
- blurred letter edges
CAUTION! Do not use methyl alcohol or other solvents on the LED heads: this will damage the lens surface.
Nov 21, 2011 | OKI C5200n Laser Printer
K drum life keeps coming up,
The best is to replace the black drum, you can fix it but you have to take apart, clean out the waste toner, replace the fuse, and cleaning blade and reassemble. The fuse will reset the printer to know it's a new drum.
Dec 23, 2009 | OKI C5200n Laser Printer
How do I find out the life left on the drum for a OKI C5200 Laser printer
Nov 12, 2009 | OKI C5200n Laser Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Oki c5200 printer driver for MAC
I also need a driver for my Oki C5200 laser and Mac with OS X Leopard. HELP.
Apr 17, 2008 | OKI C5200n Laser Printer
OKI C5200n Laser Printer Logo
585 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
