Question about OfficeMax Office Equipment & Supplies
Parts for office max omo2750
Will not feed paper
2 Suggested Answers
  • 5 Answers
SOURCE: omo2750-how do you feed checks
shredder paper jam can not get it out will not work
Posted on Aug 23, 2011
When you use the paper feed button, the machine locks--and e is displayed in the display window and you can hear a motor or cog trying to turn
Most of the time that this happen is because the printer is just dirty or have something blocking the railway. I recommend that you take it apart, and get on of those air compressor that are sold in Office Max, use to air blow whatever is loose in the printer. After that check to see if there is any piece of paper stuck.
After that it should work OK again, if it doesn't, then there could be a plastic part broken and is out of alignment.
Jan 10, 2015 | Office Equipment & Supplies
My office max OM01287 Shredder has no power to it is there a rest button it worked just fine the last time I used it and now there's no power?
Double check the safety that stops the shredder when it is full sometimes that switch gets jammed with cut paper. Also make sure the top of the shredder is level and properly seated back on the base unit. The shredder feed area may also need to be cleared there may be a staple or just paper jammed into this area as well, make sure the unit is unplugged before trying to inspect and clear and part of the shredder
Jan 16, 2013 | Office Equipment & Supplies
Omo2750-how do you feed checks through
Aug 22, 2011 | OfficeMax 0M96431 Shredder
Paper wont feed into printer
never let a machine defeat you
from your DESKTOP go to SART, PRINTER; right click on icon for your printer; PROPERTIES invoke insert cartridge selection from maintenance or tools menu. make believe you inserted new one
it then will run alignment tests and this shoudl work.
also, DUST clogs the paper roller. get spray dust cleaner at office max or staples, office depot, or big lots; spray the heck out of it to get all the dust out of the paper roller; also turn machine on and off several times. every time a printer turns on it automatically triggers the roller to spin to eject a sheet of paper (whether there is paper loaded or not). repeat this several times.
Mar 13, 2009 | Lexmark X3470 All-In-One InkJet Printer
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
Office max paper shredder switch
If you are referring to the paper feed sensor switch in the paper throat it sounds like the pc board or switch itself may be bad. I could troubleshoot a little better if I actually had you on the phone. A Customer Service Rep can help you at 1-800-945-4545.
Apr 26, 2008 | Shredder SH2006PB
Shredder
If your unit has a mechanical paper feed sensor located in the center of the paper feed area there may be paper behind it causing switch not to activate. If it is an electronic sensor you probally have a burned out sensor, switch or a bad pc board. You will need to contact manufacturer for info on part replacement.
Mar 13, 2008 | Achiever CCS5000 Shredder
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Feb 07, 2008 | Techko SH1524CP Shredder
Can't Feed Envelopes
That machine should still be under warranty. Call xerox and have them check it out.
I looked and that machine has a one year warranty, that includes service.
Nov 09, 2007 | Xerox Phaser 8560MFP Laser Printer
69 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
