Question about Schwinn Cycling
How to get a seized threaded crank bearing cup out of the frame
Still working out it with no luck and a lot of fustration tried breaker bars wont move but can see the frame twist tried punching with the brass punch and hammer anybody got ideals
  • charles beach
    charles beach Apr 21, 2014
    dont no what else to say or to do i wonder if this would fall under schwinn life time warranty if it wont come out it makes the frame useless
  • 3 Answers
Which side is the cup?
If it is gear side, don't forget that it is likely LEFT HAND THREAD so will come undone clockwise ...
Posted on Apr 23, 2014
2 Suggested Answers
sisadsl
  • 1508 Answers
SOURCE: So my Dynacraft Next turbo
the little balls are the bearings, ie: ball bearings, so they are the size, take them to a bike shop and get a replacement kit.
Your crank is probably not bent , it takes a big crash or something to bend one. there is an adusjment nut and lock nut to set them back up. could be LH thread on the left hand side
Posted on Jun 03, 2011
Engine compartment filled with water. Blew out cylinders but engine still won't turnover. What else do I need to do to fix? Drain crank shaft?
If the crankcase filled with water also, it needs to be drained and fresh oil installed. Have you tried turning engine with a breaker bar and socket? Crank bearings could be seized.
Aug 08, 2015 | Cars & Trucks
Seized threaed bearing cup three piece crank
contact local bike shop for asistance
Apr 21, 2014 | Schwinn Cycling
Failed to install in my 2013 trek mtb bike. what tools needed for us be able to install or need washer. Also need to know the comlete package and parts included when you buy it
First, you're going to need to know what type of bottom bracket is on the frame of said bike. Hopefully it will be a standard threaded BB. It could be a BB90 or PF90. If there are no threads in the BB where your BB cups then your working with a press fit system. Let's start with what should come with your Truvativ Noir Crankset. You'll have the drive side arm & spindle, non-drive arm. 3x2.5mm spacers,1x wave washer. The Noir crank uses a 24mm diameter spindle, same as Shimano. SO, if your replacing a hollow tech II crank it should be a pretty standard affair. You'll need to know how wide your BB is on the bike frame to know how many 2.5mm spacers to use. The wave washer goes on the non-drive side against the bearing. Make sure to grease the BB before installation. If there are threads in the frame you'll be using outboard bearings. If it's a press fit system you'll be using cartridge bearings that press directly into the frame. Good Luck!
Sep 09, 2013 | Sram TruVativ 2010 Noir XC 3.3 Team...
Seized engine
Could possibly be Crank shaft, crank bearing, or dropped a valve. Im assuming when you say it wont start, you mean it wont even turn over. If you say the drive sprocket wont turn then someting is stopping the crank shaft from turning. You will need to explore more of the engine to find the exact problem. Workshop manuals can be found online and downloaded if you look about, they will tell you exactly how to strip the engine down.
Jul 29, 2013 | Suzuki Motorcycles
Cant get crank pully bolt to brake lose
Take the starter off and wedge a block of wood or a pry bar against the ring gear teeth on the flywheel. That would hold the crankshaft steady. Are you using a good stout breaker bar to try and loosen the bolt? If you have access to an impact gun, that is what shops often use. Any friends or neighbors with an impact tool? If you can drive the car to a shop, you could have them loosen it for you, then tighten it just enough to get you back home to finish working on it.
Here is a method I have used and it works great, but do it at your own risk, it is not recommended: With the car on the ground, use a 1/2 inch breaker bar and socket on the bolt. The end of the bar needs to be resting on the ground, and situated so that when the starter is bumped over-just a quick bump of the starter-the engine crankshaft turns just a little bit, but the breaker bar will keep the bolt from turning with the crank-it will loosen the bolt. Just one quick bump from the starter and I was able to loosen the pulley bolt on a Chrysler this way. Lots of DIY mechanics have done this, but as I said, not recommended. But if carefully done, and breaker bar is situated in right position-it will loosen the bolt. Post back if you don't understand. Good luck.
Feb 22, 2013 | 1999 Mercury Cougar
The crank on my bike is bent so im trying to get the pedals off of my schwinn z force bmx bike but i dont know how. was wondering if you could help?
Hi, As your BMX has 3 piece cranks. Here is how to go about it:
1. Unscrew the plastic cap on the side of the crank - driveside.
2. Take your 14 mm socket and ratchet, unscrew the bolt that holds the crank to the axle. Remove the bolt of both cranks(Left and Right). You can squeeze the handle of the ratchet and the crank together like pliers to give you more leverage.
3. Take the puller and screw it's socket inside the threaded hole of the crank. Hold the crank and turn the puller handle clockwise until the crank arm falls off from the axle by itself. Remove both crank arms.
4. Go to the left side and with the pliers firmly held with both of your hands(This is where the pictures differ, I'm taking a picture at the same time.), unscrew the lockring from the bearing cup.
5. Now again firmly with both hands, grab the bearing cup with the pliers and slowly test the resistance. You do not want to slip here since this will definitely strip the thread on that cup. Hold those pliers hard and go slowly, it should get it going within a quarter turn and then you should be able to unscrew it with your fingers. If not, keep on going and be careful. Remove the cup.
6. Remove the axle and bearing crowns from both sides.
7. Remove the right side bearing cup by unscrewing it in a clockwise fashion. The notch are not very wide, so might have to hold the pliers on the cup with one hand and the handles with the other. Be aware that this cup is often very hard to remove. Again, you can always purchase a specialised wrench just for that purpose.
8. Clean and inspect everything. What you are looking for is a clean and even line on the axle and inside the bearing cups. Any pits in that line will damage the bearings and they will eventually self destruct. Replace any parts that need replacing.
9. Regrease everything, the axle, the cups and the bearings. I use regular green axle grease with a touch of white teflon grease. Make sure that everything you've pulled out of that frame is extra clean, including the hole in the frame where it came from. The most minute piece of dirt can ruin your repack job.
10. Start by installing the right side bearing cup. Screw it in counterclockwise real tight. Insert the bearings and the axle. Insert the bearings in the left bearing cup and screw on the frame. Screw it until you feel resistance. Test to see if the axle turns freely and tug it up and down to see if there is any play. No play? Turns freely? If the answer is yes to both questions, install the lockring on the left bearing cup.
11. Reinstall the crank arms tightly. I would check them again in a few weeks to be sure. When you think it's tight enough, tighten some more. That's it, you're done.
Hope this helps and please vote if so :)
Aug 05, 2010 | Schwinn S2010WMB Z Force 20" Boy's BMX...
Wont start battery was dead boost and still wont sat for awhile 6months
two things...
1.) Will the engine even turn over? Rings and bearings might be seized...you can try to crank by hand by using the correct socket on the crankshaft dampner bolt and a breaker bar ( a lot easier if some or all spark plugs are removed ) you may even find the engine is hydro-locked ( cylinders are filled with fluid like fuel, coolant and/or water)
2.) make sure you are using jumper cables that are at least 2ga
Mar 21, 2010 | 1999 Ford Taurus
1997 Toyota camry,stopped on highway,wont start
pull your plugs and then get a breaker bar or a large ratchet with a leverage bar. Disconnect your belts and remove your crank pully. Find the apropriate socket and turn it. if it moves its not seized, However this does not and I repeat this does not mean there is not a lot of work ahead of you. You still nead to find out whats wrong and then the bigger problem how to fix.
If you have no clue of what the first part of the directions are please don't try this. Taking everything apart can just make a bad problem worse.
tepfy
Nov 20, 2008 | 1997 Toyota Camry
Cycling Logo
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
