Question about Toshiba DOCSIS Cable PCX1100 Modem
Cable connection drops perodically
I have a Toshiba PCX1100. It's at least 6 years old. Recently my cable connection drops. The browser loses connection but it restores in just a few moments, sometimes as little as 1 minute to as long as 5 minutes. I have found rebooting the cable modem can sometimes help. It has gotten worse, happening with more frequency. I have used both Firefox and IE, with the same result.
Is the problem with my provider or do I need a new "modem"? Or is it something else?
If I need to replace the modem can you suggest one, I use Comcast.
Thanks.
  • robertmwaite Jun 19, 2009
    I removed Norton after running a scan with the same result. In the past Panda appeared to cause most of my connection problems, thats why I stopped using them.
    Thanks.
  • 369 Answers
It may be a problem with your security software as well. do you have norton, macafee,trend micro, panda security or anyone else. Please uninstall it and check it after that.
Posted on Jun 19, 2009
Horizontal Green Lines On Screen. No Picture Visible. Problem is intermitent.
Are you certain of the connection? Sometimes the connector becomes loose or otherwise loses integrity. Maybe it's the cable (HDMI, right?)--or both the TV's connector and that. They may become worn.
Be careful with your LCD screen--they are more delicate than most people realize.....
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
Hello! I recently moved my Toshiba 26lv610u-t from my father's place to my own. It was a short trip as we live across the street from each other. When I connected the cable to the TV, I found that all...
There are no analog channels anymore as far as I know, if you mean the channels that are local and provide an off the air signals, you need to connect an antenna for off the air signals, it may be possible that at your father's place the off the air signal was strong enough to receive them. Try going in to the menu signal type select "Air" to see if that makes a difference, of-course you will lose the cable channels until switch back to "Cable" .Hope this helps, KA
May 07, 2017 | Toshiba 26LV610U LCD TV
I had to reset my router and even reboot it because i couldn't get it to connect to my xbox. problem still hasn't worked. but now i cant even set up my wep key. it only has two options. the wep mode and...
Try cable connection, the X-Box will run better on online games anyway with cable connection.
WEP mode was obsolete years ago and represents a real security hazard.
Changing the router for a router with AES2 will enhance your security. Cable will make security better too.
Sep 08, 2017 | Toshiba WRC-1000 Router (PA3227C1ETC)
Comcast is my service provider and I have had an RCA DCM 245R modem for almost 10 years. Until recently it has worked fine. On an ever increasing basis I am losing internet connection and when I look at...
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
Aug 15, 2010 | Thomson RCA DCM245R Modem
I use a Netgear wireless router and dongle (about 1 year old, its the 3rd. router I have bought over the years) Recently the wireless connection keeps dropping, but if I plug in a LAN cable the connection...
If your wireless connection drops ,it means you need to changed channel number of router for that you need to login to router
please follow steps to login to router
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
now you would be able to changed channel on router
and check connection
Thanks you for using Fixya
May 23, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Canon BJC 80 New Cable Required
You Can Get Them At Radio Shack, Circuit City Or Best Buy Maybe Even Wal-mart
Jan 07, 2009 | Canon BJC 80 InkJet Printer
Keeps on d/c
You need to access the modem setup screen and see what the signal and signal to noise ratio is. The reason most modems drop the connection is because the signal gets weak. Since you are using cable, any connections to that cable cause it to lose signal. If there are splices, or splitters before that modem, each one can cause a 3 dB or more loss and 3dB in half your signal. When the signal drops past a specific level, the modem cannot use it and cuts the connection.
Sep 01, 2017 | Toshiba DOCSIS Cable PCX2200 (DAZ8817F-R)...
Toshiba CF36H50 turn
your problem is intermittent but from your complain it seems that your IF video circuit which is vry technical have your set checked by a technician.to resolve your problem the job will cost about $90.00
Feb 14, 2007 | Toshiba CF36H50 36" TV
Toshiba DOCSIS Cable PCX1100 Modem Logo
487 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
