Question about Home
What type of hammer arrestor do I buy to fix banging pipes after installing a new Moen posi-temp cartridge?
After installing a new Moen Posi-Temp pressure balanced shower cartridge, the pipes started banging every time the water was turned on. I read on Fixya that you could install a hammer arrestor to fix the problem. There are quite a few models of hammer arrestors and I do not know which one to buy.
    Problem Solver:
  • 19 Answers
Banging pipes are a result of improper piping support. If the piping is secured, the banging will stop. If your only option is to install chambers for water hammer, any will do. Their only purpose is to hold air.
Posted on Apr 26, 2014
2 Suggested Answers
frank00802
SOURCE: Had a leaky Moen Posi-Temp shower faucet.
Yesterday, I also repaired a leaking bath/shower cartridge in a Moen Posi-temp faucet (mod. 1222). I couldn't locate a Moen cartridge so I bought one in Home Depot made by Danco (#88675A). My priority was to correct the water leak. Today I noted that when the commode fill valve shuts off, a noise (clicking) comes from the tub that I suspected as water hammering. I tried flushing the water lines to correct for air hammer several times without success.
So that brings me to this site and I see that someone else has experienced the same problem. To correct the noise, I'll need to get a Moen cartridge. Until then, my question is: IS THERE ANY HARM DONE by leaving the Danco cartridge in place?
I can get accustomed to the metalic/hammering noise whenever the toilet is flushed and the tub faucet is shut off.
Posted on Nov 22, 2013
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
I have a posi temp faucet that has been installed for 6 years but never used. Now i have the project completed and have no water pressure thru the shower head. The sink has lots of pressure and is on the...
Have you disassembled the shower head to see if it has a flow restrictor in it. If it does you can remove it and any aerator type screens. Hope this helps. Thanks
Dec 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Had a leaky Moen Posi-Temp shower faucet. Installed an Ace Hardware replacement cartridge. Fixed the leak, but now have a water hammer noise in the vicinity of the shower. Is this a common problem with...
I'm not aware of any problems with non moen replacement parts being the cause for a water hammer problem. Start with the simplest and cheapest correction which is using a moen replacement cartridge. If the water hammer persists then you may have to install a water hammer arrester in the plumbing system. This is basically a shock absorber in the plumbing system to stop the effect of water hammer. An arrester will cost you around $10 to $15 at your local plumbing supply shop. If you are not comfortable soldering copper then you will want to hire a licensed plumber to complete the work for you.
I had the same type of problem with an older toilet in my house. It developed a water hammer when it shut off after filling the tank. I replaced the fill valve with a generic universal replacement for about $10 and it stopped. Again sometimes the simplest fix will work. Let me know how it works out.
Jul 19, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Installed new Moen posi-temp cartridge. Hot & cold water is correct but water will not shut of*** the way.
I just had the same experience, except I used a non-Moen cartridge. (It was from Ace Hardware, and Ace told me that Danco was the manufacturer.) When I pulled the cartridge back out, one of the two hard plastic seals on the side of the cartridge had torn, presumably on the sharp metal opening on the water supply pipe. I'm guessing there's something wrong with one or both of the seals on your new cartridge.
Jul 13, 2010 | Moen Posi-Temp Single HandleTub And Shower...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I replaced my Posi-Temp cartridge for the shower faucet. While the faucet now works fine, the pipes bang (water hammer effect)in the vicinity of the faucet every time someone shuts off the hot water. They...
no one ever really figured out why this happens, but you can purchase a "hammer arrestor" to solve this problem. they work good and believe it or not they are best installed at shower valve. good luck
Jan 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
94 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
