Question about Toshiba Satellite M45-S2692 Notebook
Bootup goes to black screen asks for password wont do anything else
    Sergeant:
    Champion:
  • 253 Answers
Get out your OS install CD (I'm assuming you have XP Pro- please state this whenever you post a potential OS problem) and get into the recovery console and try chkdsk /p.and for more contact http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
POS X Evo TP1 A1N screen appears to be off, but power is on
first of all check your monitor. it would be the best if you can plug some other monitor just to check... if your monitor is OK then probably you VGA is bad and you`ll have to change it.
Dec 14, 2013 | POS X POS-X EVO TouchPC (PXI-EVO-TP1-A1N)...
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
Bootup password
to be honest, your probably not going to get very much luck on this one. the bootup password, if i'm not mistaken, would be your system startup password. it's built into your bios (which is part of your motherboard). it's not even on the hard drive or the operating system in any way. no windows or anything involved. if this is the case, there's not really anything you can do aside from remember the password. however, if it's a windows password. you have several options. including small programs that bypass passwords for windows.
Oct 06, 2009 | Sylvania G-Netbook
Laptop wont bootup or sticks at the blue screen!!
Put installation cd in. Boot and when asked at end. Select repair. When dos screen starts, select operating system. The prompt C:/ will apear, type chkdsk /p this will check your partitions and repair. When it finishes you should be able to restart.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Dell Latitude D600 Bootup then screen goes black
bad display drivers, boot into safe mode (F8 on boot) it should let you use the computer, unistall the graphics drivers and reboot again in normal mode, when your in re-install the graphics again
regards
Nov 22, 2008 | Dell Latitude D600 Notebook
Acer 5610
If you get the windows splash screen and it goes black that would be an indicator that your backlight is bad. Try to hookup an external Monitor to determine this. Otherwise if you get no image at all even when you connect an external monitor. You need a new HD and must relaoad your OS, and all programs! Let me know!
Nov 26, 2007 | Acer Aspire 5610-4648 Notebook
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
