Question about Vizio L32 32 in. LCD HDTV
After running of half an hour tv giving weird sound and another 10 minutes it getting switching off and after that it was not getting switch on upto another 1 hour
Basically after half an hour of running tv its switch off before that it giving buurrrr sound.. is it SMBS problem or entire board need to change please advice .. and pls denote the cost also .. jun 2011 bought ..
  • 4 Answers
I had a vizio that had a simmular problem. I had to replace the main board. The cost on that part new is about $80 to $150. Check ebay for your part number. The part # number is printed on your main board.
If it's made by vizio the number will go something like 3842-0182-0150.
Good luck, let me know if that works for you.
Posted on Apr 22, 2014
    Top Expert:
  • Vizio Master
  • 75,581 Answers
Check and replace the damaged component/s at its audio output section circuit.
Posted on Apr 21, 2014
Left half of screen has dark rainbow effect and remains on for 10-15 sec after shut off
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Samsung LN52A850 52 in. LCD HDTV
My Sansui 32 Inch LCD screen shuts off, after a minute. The power remains on - the screen just switches off.
This may not work but i had a similar problem. My 32inch sansui LCD TV would switch off after about 10-20 minutes. I had to unplug it to get it going again. So i decided to open it as the warranty was long gone anyway. Very easy to open the back. I checked to see if anything was "swollen" as some sights suggested, but found nothing burnt , blown or swollen. Then i thought about heat? So i left in on without putting the metal backing plate back. It worked! when i put the plate back.....20 minutes and it shut down. So i just left the metal backing plate off! And no its not dangerous as the sansui has a protective plastic backing, that covers the metal one, that is better ventilated and protects the bits and pieces. Its been a week now and its fine.
Feb 15, 2012 | Sansui 32" TV
My Toshiba 32wlt58 cuts out every ten minutes.
I have just had that problem. Repairer said it was a chip in the power supply. Just got the set back this morning, ok for about 6 hours then cut out. Felt quite hot on LHS Will switch on again after a while, then cut out again. Suspect overheating problem took out PSU chip. Chip replaced but original fault still present
Oct 04, 2009 | Toshiba 32WLT58 32 in. LCD Television
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
42 inch plasma
TURN OFF THE MAINS AND THEN SWITCH IT BACK ON
Jun 06, 2007 | Samsung HP-R4262 42 in. Plasma Television
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
