Question about Currie Technologies Electric Scooter: EZIP E1000 Electric Scooter
What makes a 24volt 450 watt DC motor overheat and smoke
Will worn and chipped brushes cause this
  • Currie Techn... Master
  • 1,263 Answers
Hi, worn brushes , no unless they arcing on the motor, chipped brushes once again if they touching at a point yes they could arcing and result of that smoke, however i believe your motor could be breaking down, resistance wise , hence the fact it getting too hot because a resistance is building up in the windings,, another situation could be the controller could be burning out the motor....
check the resistance of the motor by disconnecting it and use a smart meter or electrical meter to a take the lowest ohm reading , what is it ??
Regards
Rob
www.gewizrepairs.co.uk
Posted on Apr 21, 2014
Electric motor heats up and stops after using for about 15 to 20 minutes, when it cools it runs for a short time
If the motor is heating up more than usual, a couple of things
may be the source.
a) DC 24volt Motor itself has a shorted winding and using more current than normal. In that case the motor may need to be replaced. These DC motors have a commutated armature
that uses two carbon brushes. The carbon brushed do wear
down in time, so that could also be the source. The carbon
brushes are replaceable on pretty much all scooters and
can be obtained from MonsterScooter.
b) Controller issue where more current is being supplied to
the motor, but the motor itself determines how many amps
it draws from the batteries (ASSUMING FULL CHARGE HERE)
BASED ON THE BATTERY VOLTAGE, the lower the battery
voltage, the more current is required to move the transmission.
Apr 28, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
What is the main cause for motor failure in a CT7.1 tradmill
The CT-7.1 is the exact same treadmill as the Horizon T-202.
Treadmills use brushed DC motors. It is possible that the brushes are worn out. You may be able to purchase new brushes on-line. You can source them by searching for replacement parts for either of the above two makes and models.
It is also possible that some circuitry on the control board has been damaged or even something as simple as a sensor switch has failed.
Mar 16, 2015 | Exercise & Fitness
Motor overheats
motor is working too hard.... either something is clogging the hoses or its got dirt down in the motor..... or the roller brush is binding from hair being caught in it.... clean the heck out of it.
Nov 12, 2013 | Hoover Purepower Pu2110 Bagged Upright...
What is wrong when the 11245evs drill starts smoking?
It could be that the motor isn't getting the proper current to run, causing it to overheat. Don't use long or low guage extension cords with this type of tool. If the brush holder is warped or the brushes are worn down so that they aren't making good contact with the armature the same condition could arrise. It's possible you have a short or broken wire in the armature or field that's causing it to arc and heat up. Another possibility is something wrong in the workings of the drill that is causing the motor to overwork and get hot. There are a LOT of parts in there so you'd have to take it apart and know what to look for as far as damaged or broken parts.
Jun 28, 2012 | Bosch 11245EVS 2Inch SDSMax Rotary Hammer
I would like to build a 24volt wind turbine ,I think that I have most of the Items to construct the unit but just need a wiring diagram to get started ,would you be able to help me?
allright. what kind of electric motor do you have? brushed DC or brushless? Yyu will need a controller in both situations. Actually if you have DC type brushed motor you will only need a regulator circuit. You may use one from trucks which is used to charge 24 volt battery:.
Nov 26, 2011 | Cars & Trucks
My coleman 18volt PMD8133XL drill smokes and has a burning smell when oressing triger
Hello, I hate when this happens to my tools. This could be a number of issues. I would think that the transistor that controls the motor speed is shot or the motor itself is loading the transistor causing the smoke, or the brushes internally of the motor are worn and causing the overheating, hence smoke. Is the unit new or well used?
Joe
Jan 09, 2011 | Coleman Cable Coleman 18 Volt Combo Drill...
WAs using treadmill with 2 minutes left it stopped and there was a E1 in the display... Now it wont work...
the E-1 means motor lost speed signal their a number of things the can cause this problem:
1) Motor brushes worn down to less than 3/8" in length REPACE BRUSHES
2) Motor Control Board : After starting the treadmill was their burning smell REPLACE BOARD. this condition can be caused by a worn running belt and deck Loosen belt and with a good light and inspect the weave of the belt , it should not be smooth and deck should have a dark mirror gloss with no ridges. is so they also need to be replaced.
3 Ribbon connector may defective so if the Motor Controll Board is operating the red L E D are lit one is 11 v dc and the other is 5 v dc check voltage on the upper console then if one of these voltage are missing between the boards then replace the ribbon.
Uplug unit open motor shroud and begin with # 1 plug unit back in at wall socket and due the rest Good Luck!!
Mar 01, 2010 | Exercise & Fitness
Hi i have a dewalt DC 988 combi drill, 4 years old. its starting to have a burning smell when used what are possible problems and solutions?
It all depends on what is burning I'm afraid. When in use, run your hand around the back of the machine and handle area to see if anywhere in particular is getting hot. On the older versions of these (DW988) the leads leading from the switch to the brush holders would overheat and burn, also causing damage to the brush holders themselves. Is there any smoke coming from the rear vents, if so you wil probably find it is a motor problem and the smell would be the insulation burning off the armature. The only other thing to check would be to make sure the battery isn't shorting and getting hot, as this could also cause damage to the switch and vice versa.
Feb 10, 2010 | Dewalt DC988ka 18 - volt XRP 1/2''...
Brother AX-25 typewriter won't print
If the cams assembly in the carrier unit does not cycle properly the power on routing will not complete. This problem can be caused by worn contacts in the dc motor, causing intermittent or slow operation of the cams during POR or printing. This is common with older machines. I have replaced quite a few dc motors in carrier units of this style of printer. The motors are no longer available but they may be revived by spraying a good electronic cleaner in the holes of the motor to clean the brushes (RH SIDE). Take care to not damage the plastics of the case with cleaners. If you have many machines w/ motors, you may become accomplished at disassembling the motors and repairing the brushes, but this is difficult and time consuming.
Nov 16, 2009 | Brother Office Equipment & Supplies
I have an old sunbeam mixmaster that trips the safety switch
Zaczac,
There are two probable causes for this. One is that the insulation in the motor has broken down. This is definitely an unsafe condition, and unless you are a motor repair specialist there is nothing you can do.
The other cause is an accumulation of graphite around the brush holders. Fixing this would require pulling down the motor and cleaning the graphite away. This usually happens with motors that have done a lot of work.
It is normal that by the time the brushes have worn so much that the dust causes shorting the motor needs to be serviced.
Read this to understand what is required to pull the motor down and to reset the speed control:
http://www.fixya.com/support/t2208012-sunbeam_mixmaster_12_speed_may_need
Just cleaning the motor housing out thoroughly may get the machine running. I make no guarantees though. If the motor insulation is failing the motor will remain unsafe.
Apr 24, 2008 | Sunbeam 275 Watts 2369 MixMaster Series...
Currie Technologies Electric Scooter: EZIP E1000 Electric Scooter Logo
95 people viewed this question
Top Currie Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Currie Technologies Health and Beauty Expert? Answer questions, earn points and help others
