Question about Samsung P428 R403 R428 R439 P428 R429 R440 R478 R480 Laptop Cpu Fan Ba81-08715a
Battery ok but not be charge and not open
One day suddenly it be off and then when plug put then power light lit for 3 or 4 sec and grually poer light be off,not be power on.what is problen,how i can repair it?
Fuse looks ok red light lit even without fuse no power to consol
1)Replace the batteries with full charges, with the same mark, do not mix another. with the same polarity
2) Clean the contacts cleaners very well
3) TIGHT THE spring contacts with long pliers for better contacts.
4) Adjust the REED swtich see the diagram, test for open or faulty, clean it, and tigh the connector very well.
5) TGITH the ribbon cables inside for keypds and tight lower connecer display vs lower board connector.
God bless you
Dec 13, 2012 | Nordic Track Nordictrack A2350 Treadmill...
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
Hello. I have a Toshiba c650-18k laptop . I was playing on it.and wen i went to shut down before shutting down it just went off.and wen i tried to turn it on again it is not turning on.I put my laptop on...
Is there any lights indicators lit up on the laptop?
remove the battery and the ac adaptor and press and hold the power button (for 10-15 sec) with the battery and power cable unplugged
now try powering up the laptop
check whethere the bluetooth and the power light is lit up
this indicates that there is a memory dump issue in this case you need to reseat your memory strips
for that underneeth the laptop there will be memory door
unsrew door the and open the door and you can take the memory strips out and reseat it back
Dec 26, 2010 | Computers & Internet
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
Put in a branbd new battery. Power adapter is OK.
Your motherboard does not need replacing provided the problem is the power socket on the motherboard.
If the power adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 15, 2009 | Compaq Presario 3045US Notebook
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
If I press POWER all the lights are ON only for 2 secs and then OFF again
I would remove all attached items. memories, hard drive, battery.
unlpug the AC. push and hold the pwer button for 20 sec. (discharge the PC).
plug in the AC and turm it on. (BIOS) only. if that is good, then install other devices.
Oct 29, 2008 | Computers & Internet
Not charging?
Please plug the camera charger in AC Outlet and hook it to camera. Check camera power turn ON, works fine? if OK, switch it to Standby / Off mode. Attach battery and check any charging light lit? If yes, leave the camera on charging position for 4-5 hours until its charge light flashs or turn Off. battery is chaged now. Have fun :)
Aug 13, 2008 | Sony Handycam CCD-TRV37 Camcorder
Ac power
  • just remove the battery and connect power adaptor.
  • power on the power switch.
  • try to boot tha lap.
If every thing goes well then you have to replace your battery, it might be faulty.
Thanks
Iqbal
Apr 28, 2008 | Sony VAIO Notebook
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Samsung P428 R403 R428 R439 P428 R429 R440 R478 R480 Laptop Cpu Fan Ba81-08715a Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
