Question about ASUS MeMO Pad HD 7
Screen locked and alignment wrong
The screen is permanently locked. swiping doesn't open it. also the screen is aligned wrong, unable to open it to reset. is there a reset button? fully charged. if you can help please make sure it doesn't involve wiping data as I need to keep what is on
  • Barbara Lynn
    Barbara Lynn Apr 22, 2014
    The padlock is on the screen and wont wipe off to open, when the on off buttons prssed
  • 105 Answers
To restart, press and hold the on button on the upper right of the device. Select 'Restart' from pop-up menu.
Not sure if you can recalibrate your screen.
If all else fails, perhaps you can try hard reset:
http://hard-resets.com/hard-reset-asus-memo-pad-hd7/
Try if you can avoid wiping data by selecting option not to wipe.
Posted on Apr 21, 2014
How to re connect wi fi ?
On the main screen swipe downward on the screen with your finger and you will see it says WiFi ,touch this and itxwill open up to available connections. If it says open it should connect you. If it show a lock it is acsecure site and will require a password.
Apr 30, 2016 | Amazon Kindle Fire HD
Why can't I swipe the screen?
Maybe the screen is too dirty to recognize the finger. Try getting the wipes to wipe the screen then get some screen protectors. Also there might be something wrong with the screen.
Jun 23, 2015 | Tablets & eReaders
Last Gmail I looked at is locked on screen on right side.
Close GMail first by swiping it off the running apps screen.
Uninstall GMail using the *Uninstall* option in:
Settings > Apps > Downloaded > GMail. Touch GMail and you will get another screen with an option to uninstall it. Touch the uninstall button and it will uninstall.
Then go to the Google App Store and download it again. It sounds like the Mail app got corrupted somehow.
May 11, 2015 | Tablets & eReaders
How do i get my tablet screento rotate
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Dec 11, 2014 | Tablets & eReaders
Tablet touch screen won't respond
You may have a damaged wire connecting the screen to the phones mother board
Sep 05, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
All ways to bypass a locked screen in panigram
If you swipe the pattern wrong 5 times Android should pop up an option to wait for a timeout with a button that says "forgot pattern". If you click on that button you should be able to type in the Google account info that the system is setup on and it should put you right in.
Mar 13, 2014 | Coco Android 2.1 Tablet (837121001186)
Unable to unlock screen
I had the same problem...I sent it back for a refund. Kocaso is junk as it turns out...!
Dec 31, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
Rotate screen ipad lock
swipe up from the bottom of your screen, the button on the top right is a screen rotation lock, un click or click as needed for a screen rotation lock ea9f604e-7875-4c08-8d52-4198ea08b73a.png
Dec 15, 2013 | HP EliteBook 2730p Tablet PC
IPad screen will not rotate. NOT locked, restart and reboot completed. Stuck in Vertical and running iOS version 6.1. Any solutions?
If u swipe from the bottom up, to get to the control center (or go to settings), is the orientation locked, or unlocked?
Jul 14, 2017 | Apple iPad (16 GB) WiFi Tablet PC
New playbook. Welcome screen tells me to swipe to continue to setup wifi. I swipe the screen and nothing happens
try to soft reset it by engaging the reset button ..If it has such a button it should be hidden in a hole on the side and need to be pressed until restarts ..(it should be powered and on when you do this) ..
If there is no button ..it means it has something wrong with the touch screen function ...and you should try to see if the screen is not out of focus..and try to swipe it in a certain point ..and if it is indicated..try in near by locations ...If you manage to make it start you should look in the main menu for screen calibration ..and engage it ..this should make the touch screen work proper again .
In worse case you will need the firmware and reset it to factory settings ..
Dec 08, 2011 | Blackberry PlayBook Tablet PC
ASUS MeMO Pad HD 7 Logo
174 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
