Question about Roper RT21AKXKQ Top Freezer Refrigerator
At the top of the frig where the cold air blows into a small "vent" is it suppose to still have styrofoam the inside of the small "vent"? PC Water is leaking into frig and into veg bends.
    Sergeant:
  • 272 Answers
Most likely the drain is clogged..if it is, the water flows to the path of least resistance, hence, into the air vents and down under the crisper..remove rear freezer panel. the drain pan is located under evaporator. Defrost the drain pan if there is ice in it. there will be a small drain hole. this is where you need to see it gets open via hot water and all will be ok..make sure you hear or see it flowing into drain pan...Bruce Denton, master tech
Posted on Jul 05, 2009
My Frigidaire Window Ac Unit is Collecting Water on the Styrofoam Thats Facing Inside The Home By The Vents,Why Is this Happening?
tilt your ac down on the outside,so it will drain properly,if that doesnt help,pour some bleach in the water inside to get rid of mold that clogs the drain
Apr 18, 2017 | Heating & Cooling
Milk lunch meats freezing
I have to assume you mean on the top shelf of a refrigerator. If so, then you need to look for the air vent(s) that are usually in the rear of frig compartment either on back wall or under the frig compartment ceiling. These vents are pouring very cold air from the freezer and the air needs to get distributed throughout the frig, however the coldness is falling on the milk or meats that are in the way (getting hit with the cold before the air is disipated within the frig).
Three options: if the air vent(s) have a movable or directional cover, then redirect the air so it blows away from the food on the shelves. If there is no movable cover, perhaps adjusting the freezer control (not the frigerator control) to the next colder freezer setting; this will reduce excess cold flow pouring into the frig. 3rd, make a shield of plastic or metal or cardboard to divert the direct cold flow of the air vent from falling on the upper shelves.
Oct 11, 2009 | GE PSC23MGMBB / PSC23MGMCC / PSC23MGMWW...
Seems to be filled with water In window model, on about a 10 degree pitch out the window. Some water sputters out of the vent that blows out the cold air.
Your unit has a clogged drain passage that's why the water is staying in the front of the unit.If you take the unit case off look for a drain trough in the bottom of the a/c where the metal wall is that the fan mounts to thats where it is,clean it out and the water will flow to the back of the a/c and not blow or drip inside your house.
Aug 25, 2009 | Haier hwr10xc6 Air Conditioner
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
1997 Jeep Grand Cherokee with water in the floorboard
Yes but drill the hole in the passenger compartment on the bottom of the box where it slopes down to the drain. Blow out the hole with compressed air and then plug the hole with a rubber plug or silicon. If you use silicon let it dry for a least 2 hours before running your air conditioner. Now if it happens again you have an access hole to clean out the drain. You want to drill the hole toward the firewall like you were drilling toward the drainhole.
May 31, 2009 | 1997 Jeep Grand Cherokee
My fridge freezer comprises of the top one being the fridge and bottom is the freezer. its Zanussi by Electrolux . problem is the fridge is not functioning and its warm (its not cold at all) but freezer is...
It sounds like the fan in your freezer is not working so it can't get the cold air to the frig or your coils are not defrosting and it is stopped u and cant blow air into te frig, One way to check if you hear the fan and know that it is working open the frig and put your hand up near the vent to see if you can fill cold air if you can't now open the freezer door if you can feel the cold air or more air r coils then you could before then your coils are stoped up the unit is not defrosting.
Apr 03, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Used older refridgerator not getting real cold; styrofoam coils
the evaporator coils should be on the inside of the freezer/fridge,the outside coil is your condenser coil and the air needs to be able to move freely through it for it to work properly.there may also be an auxiliary set of coils that sit in the water run over pan that helps evaporate the runoff,this run off also helps the frig work better by cooling the condenser.this set of coils may or may not have air flow usually not.If it is blowing cool air give it time sometimes a old machine needs to run for a while before it starts to work .
Mar 16, 2009 | Jenn-Air JCD2389G Side by Side...
Top rear vents blow out cold air[ 2005 cadillac srx ]
Hello according the the manual, the back vent are to blew cold air only..the fronts vents are suppose to the entire car...
Feb 01, 2009 | 2005 Cadillac SRX
Roper RT21AKXKQ Top Freezer Refrigerator Logo
289 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
