Question about Tablets & eReaders
My zeepad won't open - Tablets & eReaders
  • bong galang
    bong galang Apr 23, 2014
    Totally black screen, click the power on but still remain in black screen, I can see the green light on the power indicator, even in DC current it wont open
Zeepad does not open/reset to manufature setting
Hi Briditte, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
May 05, 2016 | Tablets & eReaders
IS THERE A MANUAL FOR A ZEEPAD 7 TABLET
Go to Settings -> Storage -> Factory Data Reset.
If that is not an option, then:
1. Power of the device completely.
2. Hold down both volumes and power at the same time. This should bring up an image of an android on its back, opened up.
3. Press both volumes at same time to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
5. Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
6. Your zeepad should now be reset
May 25, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
May 16, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Where is the battery located at in a zeepad
The battery on the zeepad 7.0 is located inside,first turn off unit then take a fine blade insert the blade ever so gently between the edge you'll see the seam with the blade inserted pry downward along the edge you'll hear it pop open as you pry down.
Jan 03, 2014 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
My zeepad screen has spiderwebed and won't register touch anylonger. is it fixable
Most places even if you have a warranty wont fix a broken screen mine has the same problem so i bought a digitized touch screen replacement on Amazon.
Feb 23, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
My zeepad won't boot up
I'm having the same problem I've tried everything and nothing's working please help
Feb 20, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
How can i unlock my zeepad 7.0 tablet
how can i unlock the screen. i charged the Bat for six hours and held down the power button but the screen shows locked
Feb 02, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
How to remove battery from zeepad 7.0 tablet
Hi open a zeepad is very easy, you need apply some pressure over the case and the screen. I recently open my sons tablets. regards.
Oct 29, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
How do i reset a zeepad
To reset your zeepad you must reload the firmware to it. For instructions go to
www.zeepad.net
Jul 17, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Tablets & eReaders Logo
22 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
