Question about Sewing Machines
Machine stopped working as its pedal was accendentally pushed hard without clothe. now it is jammed
4 Suggested Answers
SOURCE: Husqvarna sewing machine
I need the win 98 download software for hus designer 1
Posted on Mar 15, 2008
  • 980 Answers
SOURCE: I have a singer 514. I recently got a new foot
Sounds like you need to open the foot control and adjust the carbon bar, you will soon see it, just undo the screw and move it away from the contact or adjust the screw in the end.
Posted on Sep 13, 2009
Tally Girl
  • 1129 Answers
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Posted on Jun 12, 2011
Machine ran on when pedal when released, pedal now no longer works and machine wont sewing more than one layer of fabric without getting jammed
How are you making it run now since the pedal doesn't work?
You probably should take it to a repairman/shop. When this happens, sometimes the pedal is shorting out and it kills the pedal and you will need to buy a new pedal. When it ran by itself, it might have either gotten a piece of material or thread caught in the shuttle or it might have knocked the machine "out of time" and you will need to have it put back in time so that it will run properly again. I don't know what the prices are in your area but I would imagine that it will all run about $125. Sometimes you can get a used pedal off ebay (check to make sure that the configuration of the plug is the same). Good Luck.
Mar 12, 2015 | Janome DC3050 Computerized Sewing Machine...
I have a Kenmore sewing machine Model 158, 1792280. The foot pedal is not working well; I was sewing normally and when I finished, I removed my foot from the foot pedal but the machine continue sewing. I...
Jun 12, 2011 | Sewing Machines
Hello! I found a Bernina 830 at a thrift store today, and I bought it in spite of the fact that it doesn't work. I am hoping to find out what may be wrong so I (or someone else) can fix it. The problem is...
Hello Sara,
Sounds like there is thread jammed in the bobbin case area, take out the bobbin and bobbin case and make sure it is clean, also make sure the stop motion on the machine is tight, turn the balance wheel backwards if you can that should free off any jammed thread.
Dec 25, 2009 | Bernina Sewing Machines
I have everything in place to sew, the needle is in the fabric, I push the pedal, and it won't go and makes a horrible noise, the wheel turns about 1/2 a turn and then just stops.
see if it will work without the needle .. make sure the needle is not bent .. make sure you dont have a single (non zigzag) foot on the machine while its in zig zag mode .. the needle will hit the foot in this case .. if the machine will run without a needle and fails even with a straight needle then there could be a timing issue .. the top part of the sewing machine is syncronized with the bottom part via a shaft and some gears .. these are adjustable by a tech person .. everything has to happen at the right time if that relationship is changed thru slipage or wear then the machine may jam up .. also if some cloth, thread or lint is cought in the bottom unit it can cause the trouble .. will it turn by hand ?? if it turns by hand freely but wont turn with the motor ... and it makes a lot of noise .. you may have a loose belt from the motor .. if its a cog belt then it will make a shuddering noise as the drive gear slips over the cogs .. the belt tension is adjustable .. it just wants to be snug not tight, not loose ..
Sep 19, 2009 | Singer 7444 Mechanical Sewing Machine
My Singer Quantum CXL seems to be jammed
Go to this site
http://www.singerco.com/support/us_warranty.html
search for a Service Center in your state, call them for how to send in the machine and how much it will cost for repair.
sewman7
May 05, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Start/stop button problem will the machine run on its own
You have to unplug the power cord to the the foot pedal. The manual doesn't include this. And good stinkin luck with Sears or Kenmore customer service! Just pull the cord out of the machine and the start/stop button will work. Try it on a slower setting at first though. Also, if you need additional presser feet, Singer, Brother, Janome, and possibly other brands will usually work as long as they are the snap on type. I really do like my machine, good luck with yours!
Apr 23, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Machine stops after 2-3 stitches
open your bobbin case and un jam it thread wound around the center
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
I have a singer 2732 and have misplaced the manual. I'm trying to wind thread on a new bobbin but I must have forgot some part of the process. Can anyone offer instructions? Thanks!
Hi, I hope this helps. It's kind of hard without pictures, but I'll do my best:
1)With the spool of thread affixed in it's normal spot, take the thread and wind it through that weird hooky thing (like normal) at the 'back' of the machine.
2)Then bring the thread towards the front of the machine and around the metal 'button' on the top of the machine. Do not loop around this, merely guide the thread on on the side closest to you, towards the right hand side of the machine.
3)Thread your bobbin.
4)Put the bobbin on the metal arm and push to the right (gently).
5)Push the 'button' in the hand wheel in so one end of it will pop out (this will stop the needle from going up & down while you're winding the bobbin)
6)Start pressing the foot pedal slowly and things should start to work.
Jul 29, 2008 | Singer 2732 Mechanical Sewing Machine
Model 6010 Won't Stop Sewing
I would say that is the computer in hte machine
Jul 18, 2008 | Husqvarna Viking 1
Singer 2638 - three "beeps" when the foot pedal is pressed
when I stiches any cloth the thread gets lose on backside of cloth or some times it breaks how to solve is problem I am not understanding please help me.
Aug 08, 2007 | Singer 2638 Mechanical Sewing Machine
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
