Question about Dodge 06 07 08 Se SXT R/T SRT4 Diamond Grille
Dodge caliber cruise control wont engage. have replaced brake light switchh
Cruise control says set on panel but wont engage is the problem on the steer ing wheel or cable or computer
SOURCE: cruise control doesn't work
does cruise show up in led when you start engine
Posted on Sep 29, 2008
  • 512 Answers
SOURCE: Cruise Control, Steering Wheel Radio Buttons, Overhead Console
it sounds like you got 2 problems...the cruise and radio buttons sound like a bad clockspring......the overhead console problem sounds like a bad ambient temp sensor located behind the grill. if it is too cold out the ac will not run
Posted on Nov 16, 2008
SOURCE: Cruise Control Issue
The most common solution is to replace the brake light switch . The switch has 3 sets of contacts one set is for the cruise control. If the cruise control part is at fault the cruise control will not engage. The switch typically costs from 10 to 15 dollars.
Posted on Dec 25, 2008
  • 51 Answers
SOURCE: 1998 dodge grand caravan cruise control not working
does the horn work and is the air bag light on because if thats the case you have a bad clockspring. and for your year van i do belive that is a lifetime recall. hope this helps.
Posted on Mar 16, 2009
  • 64 Answers
SOURCE: 1998 dodge ram 1500 Cruise control , speed
Look under the hood to check and make sure there is two steel wire cables connected to the throttle body. i had the same problem on my 02 dodge ram, turns out that just one of the cables came loose
Posted on Sep 15, 2009
2003 dodge stratus cruise control not engaging
Catherine, Check your cruise control fuse as a first step. Could be a bad brake switch, faulty vacuum line, faulty multi function switch,etc., may have to have a good Tech. diagnose and estimate repair.
Aug 13, 2016 | 2003 Dodge Stratus
WHY WONT CRUISE CONTROL SET LIGHT COMES ON THEN GOES OUT BUT DOES NOT SET ELECTRIC CONTROLLED ACTUATOR
Most common problem is the brake "kick out" switch gets knocked out of position or adjustment. It must be pushed in when brake pedal is up, in order for cruise to engage.
Jul 14, 2016 | Cars & Trucks
Which fuse controls cruise control on a 2009 Dodge Caliber
If there is a problem with the ABS the cruise control is disabled ! you have to fix the ABS problem for the CC to work !
May 29, 2015 | 2009 Dodge Caliber SRT-4
2003 oldsmobile alero v6 -- cruise control stopped working...The cruise on/of button lights up, the green light cruise indicator comes on in the dash panel, but cruise control does not engage when CST SET...
Try checking the small switch at the top of the brake pedal. There may be two one for brake lights and one for the cruise control. To ascertain what is what, pull one wire off and see if brake lights work. If not, then the other switch controls the cruise control disconnect and engage..I you have a DC test light check to see if power is on on both side of the switch with brake pedal up. If so, depress pedal and check power on the other side there should be none, if there is the switch is defective.
Aug 02, 2017 | Cars & Trucks
Cruise control inop
if the cruise control does not activate. Check the cruise control fuse. Do a visual check of all wiring relating to the cruise control system. Visually inspect the brake (and clutch if so equipped). If these are out of adjustment, the voltage cannot get to the components down stream with enough power to operate the cruise control.
Visually inspect for vacuum leaks in the release hose and valve, If the cruise control system fails to maintain the set speed, check the throttle linkage adjustment.
Jan 24, 2012 | 2009 Dodge Caliber
The cruise control switch will not engage or set when pushing set button, but the green cruise light is on on the dash.
Check your fuse panels both inside, and outside the vehicle, as well as the connections to the cruise control.
Mar 29, 2011 | Nissan Frontier Cars & Trucks
2002 Dodge Dakota
well because the abs light indicates a problem with your anti-lock braking system you need to find out why it is on.... keep in mind one quick way you would disengage your cruise is with the brake pedal.
under the hood is a fuse panel (often located near the battery) ... see if there is a relay in the for your cruise... replace that.
Robert
Dec 17, 2008 | 2002 Dodge Dakota Club Cab
Oct 01, 2008 | 2004 Dodge Intrepid
Dodge 06 07 08 Se SXT R/T SRT4 Diamond Grille Logo
62 people viewed this question
Top Dodge Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you a Dodge Water Dispensing and Filtration Expert? Answer questions, earn points and help others
