Question about Verizon Communications enV2 Cellular Phone
Env2 inner and outer screen do not work
The inner and outer screen of my env2 do not work.  I dropped it in water and it makes/recieves call but i cannot see who i am answering/calling.  Cannot send text messages because i cant see the screen.
    Problem Solver:
  • 15 Answers
You need a new phone
Posted on Aug 10, 2009
  • redarrowprid Aug 10, 2009
    you need a new phone
    Problem Solver:
  • 14 Answers
Just take it to the verizon store and they should replace it, water damage is very serious and messes everything up as you can see
Posted on Jul 10, 2009
I dropped my env2 cant see anything phone still recieves messages
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Jul 27, 2010 | Cell Phones
My env2 screens arent workingg!!://
smoke sum weed an be happy
Dec 05, 2009 | Cell Phones
Inner Screen doesn't work on env2
it will be demaged.
contact repair centre because the upper layer can be replaced with less expence.
but do the same in your presence.
Jul 26, 2009 | Verizon Communications enV2 Cellular Phone
I dropped my env2 phone, today and the whole inner screen went black. I want to fix it but how?
i had the same problem i dropped my env2 and the inner screen went black. i tried 2 fix it but just ended up getting a new phone. you can try 2 live on the outside screen or i was able 2 bend the screen and get it to work for a while. i hope i was helpful
Jun 05, 2009 | Verizon Communications enV2 Cellular Phone
Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 07, 2009 | Washing Machines
LG Env2 dropped in water
I have this SAME PROBLEM! Any fixes?
Mar 01, 2009 | LG enV VX9900 Cellular Phone
My phone was dropped in water, it can make calls the outter screen works but the inner screen doesn't, I love my phone I wish it would work! What do I do? I can recieve messages but I can't see them
have you tried to "dry" it? remove the battery and back cover and place the phone in a jar, then fill it with rice and put the lid on it. in a couple of days, remove it and reinstall the battery to see if it works. it worked for my daughter's sidekick, but we did this immediately without powering it up as the water would cause damage.
Feb 22, 2009 | LG enV VX9900 Cellular Phone
Env2 flip screen (the keyboard screen) blacked out, but...
walk outside with your phone in hand. with one hand, hold the phone firmly. with the other, grab a baseball bat. step out into your yard, or maybe the yard of a neighbor you don't like. throw the phone straight up in the air, then grab the bat handle firmly. swing away at that bad boy. fetch the phone and repeat the process if you are not fully satisfied with how your phone functions after one whack. hope this helps
Nov 25, 2008 | Verizon Communications enV2 Cellular Phone
Both screens of my EnV2 are blank but phone works
i am having the same exact problem HELPPP ! i need my pictures and contacts
Nov 09, 2008 | LG enV VX9900 Cellular Phone
Verizon Communications enV2 Cellular Phone Logo
321 people viewed this question
Top Verizon Communications Cell Phones Experts
ismael castillo
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
