Question about Kitchen Appliances - Others
Mke deep fryer
MKE FG115 The flame coming out of the 3 burners is orange with a strong burning smell. The other fryer we use has a blue flame with no issues. What do you suggest?
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Posted on Sep 04, 2008
bigg t
  • 640 Answers
SOURCE: fryer burning really yellow flames even after
Is this a propane fryer?
Posted on Apr 13, 2009
  • 2468 Answers
SOURCE: should it be an orange or a blue flame on my
blue with just a small amount of orange flame flicker ervey now and then,if its orange more than blue your gas orfice is dirty or you need to open up the air shutter so you get more air to burn gas more completely
Posted on Nov 26, 2010
kebah
  • 683 Answers
SOURCE: pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Posted on Sep 13, 2011
Why does my burners not ignite into a blue flame
The color of the flame can be affected by a few different things. here are three of them: 1. If there is a food substance contacting the burner where the flame comes out, this will give the flame an orange tint. 2. If the propane is being burned at a very high rate, the flame can become invisible in daylight-like conditions. 3. If the propane is being burned at a very low rate it can also have an orange tint. Hope this is clarifying.
May 24, 2014 | American Range AF45LP Deep Fryer
Flames coming out the exhaust
Flames coming out of the exhaust can be caused by several things.
The fryer could be set up for natural gas and it is installed on a propane system. The fryer can be leaking oil near the burner tube and the oil is burning causing excess flame. There could be grease buildup in the flue in the back of the fryer from people hanging the baskets in the wrong place.
Feb 24, 2014 | Pitco Frialator SG18S Deep Fryer
Help flames front of fryer
Hi there.
Try to check and clean if needed the fire tubes, soot may have build up inside blocking the flame path. Soot build up on fire tubes and burners are caused primarily by low gas pressure, assuming that the orifice size are correct with respect to the type of gas used.
Regards.
Sep 03, 2013 | American Range Kitchen Appliances - Others
The flames on our pitco frialator (40lbs) are not suctioning through the tunnels and is burning an orange flame out the front of the burners instead. We are mobile unit with two 100lb tanks. We clean the...
The flame is restricted to flow inside fire tubes, make sure that all fire tubes are free of soot/ carbon deposit. There should be no air flowing (hood fresh air or any ventilation) or entering the flue box because this will cause the flame to roll back to burners. Also, make sure that the unit receives the right amount of gas pressure as specified in the nameplate, this will surely eliminate carbon build up on fire tubes and burners.
May 27, 2011 | Pitco Frialator SG18S Deep Fryer
Should it be an orange or a blue flame on my masterbuilt deep fryer
Nov 25, 2010 | Masterbuilt 20020507 Deep Fryer
Black smoke coming out of flue and two burners burn yellow flames while the other burns blue some fumes
First.. the burner tubes need to be cleanes...sounds like a few have soot build up. Messy job...do outside with a hose. Check the burner orifice size to make sure they are all the same.
Tom
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
Long recovery time during busy times have a sg 14s fryer
Make sure you have a nice blue flame in burner the more yellow that it is the less heat it put out. To adjust the flame there are air control slides on the burners there the flame comes out. Open or close them to get the proper setting. You will see the flame go yellow and blue, the bluer the better. The gas pressure could be off which you have to check with a manometer 3 lbs per water column on natural gas and 11 lbs. on l.p. gas. Check the gas valve inlet screen for dirt. If the burner system is operating properly then you have a bad or dirty t-stat
Sep 26, 2008 | Pitco Frialator SG14 Deep Fryer
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
