Question about Samsung Cell Phones
Error light continues blink - Samsung Cell Phones
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Reprogram sir!!! ^_^
Posted on Jul 05, 2014
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Blinking Light with no cartridge problems My HP Deskjet D1460 has its light blinking with no status messages that suggests an error. However, I am unable to print as the light keeps blinking. Could...
Hi
this problem has many reasons :
- no paper or error in paper feed sensor.
- jammed paper in printer thats prevent it continue.
- try to disconnect usb cable and if its stop lighting reinstall the driver
- else you must search about hardware errors
Apr 26, 2011 | HP DeskJet D1460 InkJet Printer
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Light directly below the four color cartridge lights is blinking. Won't print. Can't find my owners manual
If error number 40204 was writtent to the error log, the imaging drum is either empty or missing (I would suspect empty). If error number 10004 was written to the error log, the imaging drum e-reader may have failed. So, in either case, reinsert the imaging drum. If the light continues to blink and the Attention light (exclamation point in a triangle) is not on, turn the printer off and then back on. If this does not clear the error, replace the imaging drum with a new one. Again, if the light continues to blink and the Attention light is off, turn the printer off and then back on.
If the error persists after these steps, let us know and we can persue other options.
Mar 19, 2009 | HP LaserJet 2550L Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Cell Phones Logo
13 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
