Question about LG WFT1071TP Top Load Washer
LG WF-N7035DN machine fills the drum slowly during washing
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
MNTECH
  • 1543 Answers
SOURCE: I have an LG washing
Water inlet valve is not sealing off 100%. Replace inlet valve (the part where the hose attached to the machine). didn't find that exact model listed so couldn't give you a part number. Usually LG's have a separate valve for the cold and the hot. If you turn off one valve where hoses connect to household plumbing you should be able to figure out if it is the hot or cold. (most often it is the cold) Leave both valves off when not using washer until fixed. (note: usually on LG washers, if you have unit connected to power and the door closed, if it fills with water as your machine did, the water level switch will trip and automatically pump the water out, even if washer is not in use and the power is "off".)
Posted on Aug 31, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
I have LG WF-T7050TP, machine doesn't wash clothes. drum inside does not spin during washing timer. please help or what could be the problem?
Does the machine fill with water , does the drum turn , and does the machine pump out the water before it starts to spin
Jun 30, 2017 | Cars & Trucks
We have a LG Fuzzy logic 5.0kg WF-T507. When not working, cold water is slowly leaking into the tub. The hot water is also not flowing when needed.
The fill valve could be defective but the leakage into the machine when idle could be caused by supply line(s) above the fill valve level. Some manufacturers recommend turning off the supply between wash sessions but in practice that tends to be impractical.
Feb 12, 2017 | LG Washing Machines
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
Lg washing machine WF-F6517THZ manual
I have LG Washing Machine model# WF-F6517THZ . i need to know where i can get the filter, which is in side the drum.
Jan 15, 2013 | Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
