Question about Jenn-Air Kitchen Ranges
Clean button beeps twice but won't start clean cycle
Has cleaned 4 times before successfully, but neither top nor bottom will go to 'Set'. Ovens are cool, doors closed firmly
  • Aryd'ell Hotelling
    Aryd'ell Hotelling May 08, 2014
    Hubby could reach plug, where I couldn't. Unplugged for one minute, then replugged. Works fine now. Probably a glitch due to Duke Energy's rolling brownouts :-( .We have our other appliances like washer and fridge, computer and monitor, etc unplugged or running through a battery backup, but didn't want to do that with the stove. Rethinking that, now.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Faulty switch.
Posted on May 08, 2014
  • 76 Answers
SOURCE: self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Posted on Dec 13, 2006
  • 1314 Answers
SOURCE: GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
  • 409 Answers
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
  • 38 Answers
SOURCE: Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Posted on Oct 28, 2008
SOURCE: Wolf oven self-clean error 01
Well, ours is working now. We called Wolf, they said the Error 01 indicated a problem with the latching mechanism (that locks the oven during self clean).
We called the local repair outfit (they've been here several times before working on this range), they ordered a latch mechanism and arrived today to install it. The tech this time had worked at an electronic company that I also worked for about 10 years ago (I'm an electrical engineer). So we had a good time talking about the old days and working on the range - I'm always curious about such things. We removed the latching mechanism - its an assembly with a motor and a couple of switches that are used to start and stop the motor. We tested the switches and motor using a meter and power cord. Seemed to be OK. The next thing would be the control board - which we had replaced about 3 years ago - under warranty. Before removing the control board we reinstalled the latch mechanism - and, of course, everything worked fine.
We were both a little dismayed about the quality of the assembly of the range - the wiring looks more like a rat's nest than the tidy routing that we'd like to see.
So, bottom line, neither of us knows what the problem was. Could have been a food particle lodged in the switching mechanism, an intermittent connection or ???.
One thing I noticed as we checked out both ovens: We put the small oven (the one that was having problems) in self clean for a couple of minutes - was OK. Then we turned it off and turned the larger oven to clean mode - when we did that, "OPP" appeared on the display. The tech said that was because the latch of the smaller oven was not in its stop position yet. We gave it a few more seconds then tried clean mode on the other oven and it was fine. I mention that because OPP appeared on the small oven once or twice when we (my wife and I) were initially trying to figure out what the problem was. There's probably a hint in there somewhere as to what the real problem was.
At any rate, its working again ($115 later) but I'm not real confident that it will continue. Next time, I'll open it up myself (not recommended). <g>.
Posted on Nov 07, 2008
Used the self cleaning option and now top oven will not heat?
Good Morning Friend,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
Ge monogram bottom oven won't clean
Follow the owner manual instructions, some condition is not set or the door switch or door lack it not operationg. Could be the monitor switch on the oven latch.
Mar 02, 2013 | Ovens
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
How do I start bosch exact temp self cleaning oven
My Bosch is also self-cleaning. If you press and HOLD the 2 buttons Bake and Broil that will lead you through the process. It starts by beeping at you- don't give up. :D
It will remind you of several things:
Choose length of time (4:00 is standard)
Remove the racks (self-cleaning will make them 'sticky'
and so forth
Keep pushing Start if you are comfortable moving forward.
Hope this helps!
Apr 28, 2012 | Ovens
I need to clean my double ovens, but do not have the owner's manual. I know that I simple press the Clean button, but how long do I set the timer for?
You only need to reset the time if you want a cleaning cycle other than 4 hours. The default start is press Self-Clean then Start. Otherwise, press Start, type in a time between 3 and 5 hours (Min/Max cycle length) and then press Start. Do this with the number pad, do not press the Timer button. If you wish to clean both ovens, the second one will start when the first one finishes.
The Locked door light will go off when the oven has cooled below the Lock temperature. If you interupt the cleaning cycle by pressing Clear/Off, the door will remain locked until the oven cools.
I hope this helps.
Sep 25, 2010 | GE Profile JTP56 Electric Double Oven
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
When you turn oven on auto self clean light flashes cleaned oven 3hrs light still flashes bottom element not getting hot
The clocks tell the stove when to start and stop. Has you set the timers right? In other words if you have the start time set to 6pm and it is now 2pm the clean cycle cant start for another 4 hrs.
Oct 04, 2009 | GE Ovens
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
How Do I Use Self Clean Oven Feature?
Kathy - we just figured ours out!! Hit the clean buttton, will light up With "cl n", hit 2nd time and it will start the cleaning. Ours set for 4 hrs! Good luck!! This is for the maytag performance!
May 28, 2007 | Maytag PER5705 Performa Electric Kitchen...
Kitchen Ranges Logo
60 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
