Question about Insignia NS-L322Q-10A LCD TV
TV will not come on
When I try to turn on the tv either by remote or by hand it will click like it's coming on the red light will go away but instead of coming on it clicks off and shows red again
  • Michael Bowers
    Michael Bowers Jul 01, 2014
    I changed out the main board and it continues to do the same thing.
    Top Expert:
  • Insignia Master
  • 74,468 Answers
Sounds like main board fault. Contact any service technician. Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among its posts have details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
Electro help
Posted on Apr 21, 2014
SOURCE: insignia lcd tv 32"
have good tec replace if nessary, The inverter module
Posted on May 10, 2007
  • 27 Answers
SOURCE: tv won't turn back on !
the tv has been shorted out. you will need to replace the power board easy to do just take off the back cover and its the only board right in the middle with the power wires on the bottom . there are 4 screws to remove and unplug and label the wires and replace put back together and should be good as new.
Please rate my answer its much apreceted
Posted on Feb 13, 2009
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
SOURCE: Insignia 32" TV turns off after turning on and red light comes on
Hi
I have Philips 42pf9431d/37b and i re hucked up my tv.
It truns on and goes to green and red how can i solve it.
Posted on Apr 12, 2009
walesarumi
  • 6993 Answers
SOURCE: my insignia LCD tv 32
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 21, 2011
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
Just bought an ANTSIG 4 in 1 universal remote control and cant find the code to operate an LG vcr.. can you help ?
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. I have only tried this with an LG TV. Hopefully it helps you out. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working. Maybe you'd need to press something else instead of TV for a VCR? But the trick is to be about 1mm away from the signal receiver. I literally put it in front of the red light of the tv.
Feb 03, 2011 | Televison & Video
Need help programming philips universal remote for a sanyo tv
Here are the codes,0506,0311,0612,0002,0428,0802,0412,0619...Turn TV on. Aim the remote at the TV,Press and hold CODE SEARCH button until light turns red, press TV, the light will blink once and remain on,enter one of the four digit codes, the light will go off, if the light flashes instead of turning off, you will need to try another code until it does, press the POWER button, the TV should turn off..... hope this was helpful...
Apr 18, 2010 | Philips Universal PH301S Remote Control
I cannot find my instrution manual. Help!
Here are the codes, 002,003,004,005,104,105,106,115,205,204,206,213,304,305,316,319,405,502,505,506,519,604,605,705,804,805,903,904,905,906...Turn TV on,aim the remote at the TV,press and hold the code search button until light turns red,press TV,the light will blink once and remain on,enter one of the three digit codes, the light will go off,if the light flashes instead of going off, you need to try another code until it does,aim the remote at TV and press POWER button, the TV should turn off....hope this was helpful...
Apr 17, 2010 | Philips PM335 Remote Control
We have a Philips 4 BDS4231R/00 and it does not start. We can here the relay sound and if we turn it on and off say 7 - 10 times it works fine. Could anybody tell me how this can be fixed. Please
Hey John, I am experiencing a very similar problem. If I unplug the TV when it is on (green light) and plug it back in. It begins green, and clicks to red. I immediately turn the TV back on with the remote. Most of the time it seems to struggle for several seconds, sometimes with a little scratchy audio popping in and out. It will then go from green to red on the TV and if I try to turn it back on it will go green for a few seconds and back to red but without any click coming from the TV. No matter how many times I try after that, no TV. If, on the other hand, I unplug while green, plug it back in and with the remote turn it back on after it has come up green and then clicked to red, it will come on. It might take thee or five times but at least it comes on... If you hear of a real solution, please let me know (bennettkw@hotmail.com) in the meantime, best of luck.
Dec 28, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV wont stay on
no reset button on the tv maybe the tv is shock when you switch on the tv cause sometimes lizard always stuck down the pcb...try check the horizontal output
Dec 08, 2008 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
TV won't turn on
The red light instead of green is an indication that theres a voltage missing or an improper voltage in the sweep or main power supplys. This should be handled by a trained service tech. Good Luck
May 28, 2006 | Durabrand DWT2704 TV
Insignia NS-L322Q-10A LCD TV Logo
108 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
