Question about Technogym EXC Run 700 Treadmill Refurbished
Equipment blocked technical support(4)
Machine always shows equipment blocked.contact technogym technical support(4)
Technogym run excite 700 shows COM error equipment blocked
There is a fan in the iron box. You have to change them. 2 fans required. Change both.
Feb 04, 2016 | True Technogym Excite Run 700 Treadmill
My techno gym treadmill 700 indicates equipment is blocked code (4) how do I fix this problem. Thanks
Can be one of many problems.
Can be as simple as a limit switch not resetting.
Can be a cable is bad
More often than not it's the lower kit (electronics near the motor) that is blown though.
Mar 09, 2015 | True Technogym Excite Run 700 Treadmill
How to fix "The equipment is blocked (com)" error on technogym treadmill's display?
Equipment is blocked can be a number of things.
Not sure what MOSFET is.
First, and usually the most popular thing is the electronics.
Other usual things to look at:
-the emergency stop can be malfunctioning. Does it move or is it fixed still? That's something I just had to repair on a treadmill recently.
-A cable could be loose. Try taking a Cat 5 cable from the lower kit directly up to the display and see if that does anything. This isn't a common issue, but worth a shot.
May 20, 2014 | True Technogym Excite Run 700 Treadmill
Technogym cross trainer - equipment is blocked 16
Equipment is blocked is unfortunately a common 'error' that shows up with Technogym, but it refers to a number of errors.
-Does your emergency stop swivel a lot, or is it fixed? If a cable has come off inside, that can be the cause.
-A loose cable running up the arm of the frame is the next thing to look at.
-Lastly, and most common is the motor controller has fried. It's a common thing with Technogym, and is an expensive repair. Technogym will tell you that you have to replace it, but since it's electronics it can be repaired, as long as someone knows what they are doing.
Where are you located?
Apr 20, 2014 | True Technogym Excite Run 700 Treadmill
Treadmill display problem
The equipment is blocked... (2) this is the message I get in my Run excite 700 technogym treadmill.
Can some one help.
Thanks a lot
Jan 08, 2014 | True Technogym Excite Run 700 Treadmill
Monitor shows equipment block what can i do?
please Pressing SCREEN LOCK a second time will unlock it as well.
God bless you
Jul 30, 2013 | True Technogym Excite Run 700 Treadmill
How can i solve problem bloked (2)
Do you know how to RUN software calibration for diagnostic?
Because I have the same problem.
May 27, 2013 | True Technogym Excite Run 700 Treadmill
hi all i have run excite ur 500 treadmill from techno gym company i face block on screen i think it's board problems if anyone can have any idea contact me at email: alex.freemas@gmail.com
May 08, 2012 | Exercise & Fitness
Technogym EXC Run 700 Treadmill Refurbished Logo
57 people viewed this question
Top Technogym Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Technogym Cycling Expert? Answer questions, earn points and help others
