I have one hard disk that is blocked how we get solution, Model No.TS500gsj25A3k Sereal No.B223840472
  • 3,320 Answers
" Blocked" doesn't mean anything.
Posted on Apr 22, 2014
Bloacked
Try connecting to another pc. Change cables.
Apr 21, 2014 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Tip
How To Fix Bad Sectors on the Hard Drive
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Feb 03, 2011 | Computers & Internet
Transcend
CHECK T IN DEVICE MANAGER AND DISK MANAGEMENT
Apr 20, 2014 | Computers & Internet
How to remove bad sectore of hard disc? s/n=0415j1ftc02540
Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | Maxtor Hard Drive
Ran Dell diagnostics and SATA Disk Confidence test failed, Error Code 0F00 1332,Disk Block 30819848(etc)IRQ did not set in time. Dell Inspion 1545 laptop with SATA disk s/n 5VC2W51X
consider to replace your hard drive, your hard drive detected crash on your bios so you have to replace it. your hard drive can be use to external hard drive buy some external hard drive case 2,5"
you can re partition your hard drive and maybe if you are lucky the harddrive can be use again on your laptop
Jan 16, 2011 | Dell Inspiron 1150 Notebook
When i connect my hard drive to my laptop it does not show how much data on my hard drive and it has asked me to format my hard drive
Is it a "brand-new" external storage device? If so, then it must be "initialized" before being used for the first time.
If you have been using it, then the "Table-Of-Contents" on the disk-drive has become corrupted.
Since Windows does not recognize the data as being a valid T-O-C, Windows is asking your permission to write a new, valid, empty, T-O-C onto the disk-drive.
Perhaps, all the other blocks of data existing on the disk-drive are still valid.
Look online for a "file recovery" or "file scavenger" program,
which reads through the disk-drive, block-by-block, trying to "stitch" the blocks together,
to reconstruct your files.
Nov 04, 2010 | Maxtor (6L250R0) 250 GB Hard Drive
I have samsung (Model hd501hi) hard disk but it
Hi. Sounds like a problem with the harddrive boot block. Try the torubleshooting steps i provided to you below. If same issue appears after thes troubleshooting then theres a need to replace your Harddrive.
* If you have a floppy try to boot with bootdisk http://www.bootdisk.com/
if you have a bootable windows CD - try booting that then go to the repair console.
have a good one!
Jul 29, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Sereal number for nero 6
I cannot supply you with Nero 6 serial number BUT -
You can download for a free copy Nero 9 software from this WEB site :-
http://www.nero.com/eng/downloads-nero9-free.php
May 28, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Lost seagate freeagent PRODUCT KEY
WIth the original freeagent disk in hand,call Seagate and ask if they can give you the product key based upon the sereal number on the disk. If you purchased freeagent on line and downloaded , they wil have a copy of your invoice purchase . Just contact then as ask again for your product key.
Jun 19, 2009 | Seagate FreeAgent Pro 500GB External USB...
Need new instruction manuals garman GPS map492 sereal #70405694 & Garman Fishfinder 400c sereal #12c005161 thanks milton
you should be able to get them from garmin website and download them in PDF for free
Jan 26, 2009 | GPS
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
