Question about Samsung Televison & Video
When i press the smart hub button it just says starting
The tv is connected to the internet but smart hub will not start. I have to reset everyday which is annoying. It will also not save the channel list to a usb once I have reset everything
  • davey_donohu Apr 21, 2014
    This is a samsung seies 8 smart tv not a network or switch problem
    Problem Solver:
  • 6 Answers
Do software up date first off. Make shure router is set to DHCP.
Posted on May 12, 2014
SOURCE: My Sanyo Tv (model dp327460 is Busted
You should try and download the users manual if you do not have one...I remeber seeing in it that after hooking every thing up, you have to do the channel search twice before the unit will work properly..This is highlited in the manual with correct hookup diagrahm..
Posted on Aug 10, 2007
  • 27 Answers
SOURCE: Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
johncaman
  • 201 Answers
SOURCE: tv screen says no channel listed
Do you have a separate cable converter? In that case, the tv must be set to channel 2,3 or 4 (depending on the box) and you use the converter's remote to change channels. Otherwise, go into the setup menus for your tv and look for 'tuning' or 'source' and make sure it's set to 'cable' and not 'antenna'. Hope this helps!
Posted on Mar 04, 2009
freetek
  • 5568 Answers
SOURCE: Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Posted on Jun 15, 2009
AJIN G
  • 6694 Answers
SOURCE: hit the reset button on remote and now tv is not
hi,
when you press the reset button the tv has gone to factory setting. All the settings made by you have been erased when you rested the tv. you have to set all channels by auto tinning your tv. also you have to set picture setting according to your preference, because the tv is now in factory default setting.
ok
Posted on Feb 14, 2011
I bought a Samsung BD HDD Combo from a seller on facebook. I no longer have his contact details and I need to know his PIN number. How can I get around this?
Not sure if this will help
Reset
The Reset function initializes all downloaded
widgets, erases all user accounts and settings
from the product, and resets all Smart Hub settings
to the factory default settings. It then restarts
Smart Hub as if it were starting for the first time.
Your account, however, remains on the Smart Hub
server. To log into your account, enter your ID and
password on the Create Account screen.
To use the Reset function, follow these steps:
1. In the Settings menu, select Reset, and then
press the ENTER button.
The Reset screen appears.
2. Enter the your Security password. This is the
password you entered if you set up a BD or
DVD Parental rating (See pages 51~52). If you
did not, enter 0000.
Samsung BD D8900M User Manual
Nov 13, 2016 | Samsung Televison & Video
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Sep 20, 2016 | Samsung Televison & Video
Can my Samsung 46" LED TV connect to the internet
If you have purchased a Samsung smart TV with Smart Hub you will be able to connect to the internet using the web browser found in the Apps when running Smart Hub function.
You will need to have either an Ethernet cable connected to your TV from your router or you can connect using WiFi is your TV is so equipped.
You need to use the menu to go to the internet connection setup.
I hope this answer is helpful to you.
Mar 01, 2015 | Samsung Televison & Video
How can i get my smart tv to connect to the internet it is already connected to my wifi but when i click to connect to the internet it comes up no internet connection?
Check to see if your laptop or phone gets online via wifi to see if wifi is on the net, and try rebooting your wireless router by unplugging, then plugging in. (do not press "reset" button on router)
Feb 26, 2015 | Televison & Video
How do I get Netflix on my tv
First you need a Netflix account. Then, if you have a smart TV, it needs to be connected to the internet and have the Netflix app. If your TV is not smart, your DVD player probably has Netflix on it and that needs to be connected to the internet. Then you have to log into Netflix on your computer and authorize the new device. They will give you an activation code to enter on the device.
Feb 13, 2015 | Samsung Televison & Video
How to connect samsung smart tv and netflix with ui-113 error code
I have the same issues, I tried everything from disconnecting the modem to resetting the TVs smart Hub, I also tried all Netflix recommendations and I am still having the same problems, please help if you have a solution
May 25, 2014 | Computers & Internet
What do you have to reset when you change the bulb
Press the Menu button on the HTS remote control and then move to Setup and press enter on Reset.Launch Smart Hub from the home menu or by pressing the Smart Hub button on your HTS remote. Press the Blue D button to bring up Account Management and then move to Reset and press enter on your remote. Enter the BD or DVD parental rating password; if you did not setup a password enter 0000.
Smart Hub automatically resets, the screen may go black and then re-appear. In a few moments the re-initialization procedure starts and the Terms of Service agreement is displayed, follow the on screen prompts to complete installation.
Sep 17, 2011 | Samsung HLP5085W 50" Rear Projection...
Televison & Video Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
