E01 error candy evo1483dw
Locking for dor fall in to machine. I took the cover off and place the door lock back into place, but after I put it back it showed e01 error, please help
SOURCE: HE3t f20 error
We had the same problem with a new machine. We washed one load successfully and the second time we got the F20 code. Sears came out and determined it was a bad valve. They had to then schedule another service call to fix it.
The new part was shipped to our house. The repairman showed me the old valve with some black debris on it, saying that our lines were dirty and that contributed to the problem, but its hard to understand how one use of the machine would clog a good valve. Anyway, with the new valve the machine works fine.
Posted on Oct 30, 2007
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
SOURCE: whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Posted on Jul 03, 2008
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Posted on Jan 22, 2009
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
Washer is showing error codes F09 and E01 we did what the manual said and it didn't fix it what should I do. The door lock is on and the door want open.
unplug the machine take the top off and push the drum to the rear and using a small screwdriver remove the door lock and replace it from the manufactures website spares department good luck eric
Jan 15, 2018 | Washing Machines
FO6 E01 error code on Whirlpool Duet washer
go online whirlpool support ..they can tell u quick by the error code it displays..but I had Samsung last week do very same thing it was off balance sensor..good luck..and once you get sensor very easy to put new sensor in..
May 22, 2016 | Whirlpool Washing Machines
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
How do i fix a door lock on a candy washing machine
go too you tube
type in your candy model and door lock replace etc string get some video help you would be amazed i found over 50 models covered and in great detail
Dec 19, 2014 | Candy Washing Machines
How to fix error e23 on toshiba washing machine. machine runs for a whikle and then stops
Error Code ( E-23 )--------Clean the LID LOCK sensor,its almost located where you can see the LID LOCK came OUT and IN or Moving--which is functions to LOCK and UNLOCK the door cover ( Symptom ++ the LID LOCK will moving OUT and IN),open all the cover ,take out the LID LOCK sensor,open the LID LOCK sensor case until you can reach the COPPER connector which is act as the SWITCH .CLEAN the COPPER with paper sand or anything possible but not to damage the copper.After all put it back to the place intact.Hope it work,Mine worked with this procedure.+++++Toshiba AW-SD120S COST=== FREE OF Charge ( Do It Yourself )
Jun 10, 2014 | Frigidaire Affinity ATF7000E Front Load...
Hi, my candy washing machine is not spining.i open the back to see the belt had fall off ,and not snap.i put it back but it won,t spin. help
not spinning can be related to door lock the door is a saftey switch if not working correctly will not spin but this is for front loader unit also if the pump doesnt drain in the time it should unit will not spin u also could have a failed motor ,motor control etc would need model # to be of any real help most machines have common prob
Apr 29, 2010 | Candy CN146 Front Load Washer
How do you change the door lock
Removed the rubber seal on the base of the machine. then removed 3 screws from the outside of the door lock, unepluged the 3 connections. and replaced the locking mech. put the rubbed seal back in place. It took me only 20 min. to do with a little help with replacing the strap for the seal.
Apr 17, 2009 | Kenmore Washing Machines
E01 Error
The rice cooker lid has to be closed and the dial knob has to be in the lock position (turing on the pressure lamp) before cooking can start. There are two tiny wires sending signal to the main controller to indicate that the cooker is in lock position. The wires are vey tiny and they can break over the years as a result of opening and closing the lid many times. When these wires are broken, the main controller cannot detect the lock position and will give E01 Error.
Feb 02, 2009 | Panasonic SR-PRA18N 10-Cup Rice Cooker
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
