Question about KitchenAid Dishwashers
Dishwasher won't start
We have a KitchenAid model Kudlo21rbso. It is 3 years old and has been great til a couple of weeks ago. When you hit the start button it won't start. we hired an electrician to come out and see if was an electrical problem. he said there is power to the dishwasher. we hired a dishwasher repairman to come out and he replaced the control panel. unfortunately it still does the same thing. if you hit enough buttons it will light up and make noise like it is going to run but after about 10 minutes the lights go off and the noise stops. it never runs any water into the dishwasher. any hints on what i can do please let me know thanks
ngfam1
  • 639 Answers
SOURCE: i have the kitchenaid dishwasher
Dear friend,
ngfam at you service! happy to assist!
It's an electronic problem!
The lights are called codes and need to be diagnoed by a factory service person!!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
SOURCE: control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Posted on Sep 21, 2009
rickead1
  • 1998 Answers
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
KitchenAid Superba leaks from filter housing
i would definately change the filter
they are usually only good for 6 mos
or 400 gals
without knowing if its dripping from the housing
i would start with changing the filter and see if that takes care of it
AP3182816
i just checked and thesea re on sale
30.00 is pretty cheap
appliancepartspros.com
i used to sell these off my truck as a maytag guy
for 48
let me knoe
Oct 17, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Blank e mail page with"done" at bottom for 2 weeks now!!!
You should be able to see those emails after hitting F5 from the keyboard a couple of times.
Also, try clearing your cache:
For IE, click Tools, Internet Options. In the general tab, under Delete browsing history, delete ALL.
Further, flush your DNS. Open a command prompt, then type:
ipconfig /flushdns
Jul 18, 2009 | Yahoo Mail
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
1995 Saturn SL2 Continues To Stall
I had same problem a couple years ago with 95 sl2, i had new wires and plugs instaled and they replaced the valves also. car works great since then...
Jan 07, 2009 | Saturn SL2 Cars & Trucks
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Kitchenaid start button wont work
I am having the exact same problem with ours. I decided to take it apart and have a look. After unscrewing all the stainless torx bit screws on the inside of the unit you can access the control panel. Underneath the buttons on the unit there is a circuit board with the switches mounted to it. The start switch on the board is corroded. I tried cleaning it but it did not help. On the board there is a part number stamped 8530995. I have found the board online for $47 and I've ordered it. The board pops out and has a connector attached to plug it in. To access the board you'll need a set of torx bits and a flat head screwdriver.
Jan 29, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
66 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
