Question about Garden
Masport mulcher runs the wrong way?!
I have just brought an old Masport 2.5 HP mulcher/chipper. Tried it this afternoon and all it does it jam everything in tight instead of forcing it out the outlet. I then discovered that the design of the outlet needs the blades to run clockwise, yet the motor runs anti-clockwise, forcing the mulch back into the blades, making it finer and finer and blocking the machine. I can only assume that someone has modified the machine at some point, else I am missing something here?! It does have a red button which I was hoping would be a reverse, but it does nothing. Any ideas?Cheers
  • 1550 Answers
SOURCE: sweeper-mulcher starter cord won't move
It indicates something locked in mulcher blade .
This can be fixed by professionals only.
Posted on Nov 09, 2008
bunnydawg
  • 5158 Answers
SOURCE: blades for mulcher shredder
http://www.ryobi.com.au/
Posted on Mar 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: Imurray 22" psuh mower will not stay running
No problem. If you found this helpful - a FixYa rating is appreciated for answering your FREE question.
Posted on May 13, 2009
  • 69 Answers
SOURCE: Will start and run for 3 seconds and then stalls
Does it have a primer bulb on the side of the engine? If so, it is probably a bad bulb, or the hoses connected to it. You can prime enough gas to start the engine and briefly run it, but the cracks in the bulb or hoses allow air to get sucked into the carburetor not gas. This is what kills the engine. You can pick up a repair kit at just about any hardware store for less than $10.
Posted on May 27, 2009
  • 1114 Answers
SOURCE: Mowing blade turning the wrong direction
I think you did diagnose the problem. A DC motor will run backwards if the wires are switched around and polarity is reversed. Try switching the wires
Posted on Jul 02, 2009
Masport Morrison parts manual for 1995-1996 lawnmower? motor is a Briggs and Stratton 3.5hp 10A900 series
find the model # and type on the crown of the pull started (there stamped in.
Go to Briggs&Stratton Parts
Nov 08, 2013 | Garden
What fuel does the masport 625 190cc series lawnmower/mulcher use?
What ever you whant as long as it is unleded,Super is not the best to use for older equmint,to high of oxtain.premeum, is good for high reving older moters,Regular is the best bet though...
Sep 18, 2011 | Garden
No recoil on cord on craftsman mulcher,chipper,vacuum
sounds like your spring is broken in the rewind you need to replace the spring
Nov 04, 2009 | Troy-Bilt Chipper Shredder
I have a troy bilt mulcher model 47057 serial number 470570100839. We need to buy some more blades etc where would be the place to buy the parts from
I would check with an MTD dealer. I look online and found a site for the chipper blades and they wanted $40.00 USD for each. It may be worth your time to take the other ones out and get them sharpened.
Good Day.
Oct 12, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Need manual
CSV 206 Chipper Shredder Vac / Mulcher
http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_10109_54995_-1_details
CSV 070 Chipper Shredder Vac / Mulcher
http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_13809_54995_-1_details
There is option to "Download Owners Manual" on the left hand side.
Aug 23, 2009 | Troy-Bilt Chipper Shredder
Flowtron LE 900, The Ultimate Mulcher, just quit
I found a reset switch on the leaf-chipper. I was then careful to fill it more slowly, and to keep out sticks and clumps of wet leaves.
May 28, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
I have a Huskee chipper/mulcher that won't start.
Engines need 2 things to run. Fuel and spark. Pull the spark plug, re-connect it to the wire and hold the base of it near the motor. Like about 1/8" near. Pull the cord (you'll probably need a helper). See a spark? yes? Ok that eliminates that.
Fuel is where the problem usually is. Is the fuel in it from previous seasons? Did you put stabilizer in it? Dump the fuel, put in a little fresh fuel and pull over and over until your fresh fuel can get into the carb. Still not popping? Your carb is likely clogged from the residue left from stale fuel. The easy way to deal with that is to replace it, but that can be $60 or more. The next easiest way is to get a carb kit and replace all the gaskets and parts it provides (that apply to your particular carb) while cleaning it along the way. The harder but cheapest way is to take it apart and clean it, trying to re-use all the parts. If you could do this you would not be posting here. If you are the put-in-gas-and-oil-and-pull-the-cord type, bring it to a shop.
Apr 29, 2009 | Heavy Machinery
Mulchers safety measures
if you are using a blade mulcher be sure to keep your hands out of it!
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
